And you have to say Nico has been doing the better job. Lewis has been messy a few times this year....Nico just fets on with it and never makes a mistake of consequence
yeah it was interesting hearing his radio comments as the issue unfolded, asking calmly for what to do... and then when the shit hit the fan he looked at the bigger picture and just wanted to limp around, most drivers so far get angry and just want a fix....
Have to agree. Cant help but feel Lewis would have just said "come on guys, we can't have this" then had a winge after the race.
Despite having double the number of DNF's, Lewie still has 66.67% more race wins than Rosbergo
So I, respectfully, disagree with that assessment
Interesting to see the Merc power unit in more detail. I was of the belief that they were running a big single.
http://www.formula1.com/gallery/testing/2014/863.html
That photo confuses me. They do run a big single, its in the regulations:
A Formula One car’s power unit consists of a 1.6-litre turbocharged V6 engine which operates in conjunction with an Energy Recovery System (ERS). The engine must have six cylinders in a 90-degree formation, with two inlet and two exhaust valves per cylinder and a single turbocharger. They are rev-limited to 15,000rpm, have a fuel flow limit of 100 kilograms/hour and produce around 600bhp. They must also have a single tailpipe exhaust.
But seen as they have what appears to be the best engine at the moment, I wouldnt be suprised if they were putting out a display engine that isnt exactly what sits in the cars. At least it looks like its some sort of display section its in anyway.
but the Canada retirement was due to Hamilton not having the awareness to identify early enough, and/or the mechanical sympathy to nurse the car home with the same issue Rosberg had... so Hamilton is responsible for that retirement.
Edited by hrd-hr30
fair cop maybe; his driving style prefers a little more rear brake bias, which shows up the marginal nature of the rear rotor thickness when the drag induced by ERS harvesting is taken away
consider if he'd finished third though, he'd be 11 points ahead rather than just 4 shy
they indeed do
the uniqueness of the Merc setup is that the compressor and turbine housings are at opposite ends of the engine with the connecting shaft running through the MGU-H motor in the center of the V, thereby giving a more optimal route for the intake pipework
When he is on it he has done a good job. But when he has had his mech failures he has been behind Rosberg. When Rosbergs car failed he was in the lead. But thats only a small part of it.
The main reason for saying it as its not even a case of being out qualified by Rosberg, but more the point that he has thrown away 3 (?) qualifying sessions now by being a hack. I mean he has had woeful qualifying where as Rosberg has done everything needed from him.
As Harry pointed out...I will refrain from criticizing Hamilton for the retirement in Canada but I think its important to credit Rosberg with how he handled the situation and bagged a second place.
So just have to cross fingers that Lauda and Wolff let them continue to race each other
http://en.espnf1.com/f1/motorsport/story/166621.html
"Different teams have developed the technology to different extents, with Mercedes believed to have one of the most effective systems"
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
