let's try that in context, shall we...
doesn't sound like he's being a tool to me.
The context that SebVet has created is an interesting one but does anyone else actually believe that his lack of relative speed has been due to inferior equipment nearly every weekend?
I don't know, but I do know neither had car issues during qualifying yesterday and Vettel's faster :P
Should not have to much impact on result as Vettle qualified better than Dan both times he has won IIRC
Tool had a new engine? Interesting to hear from the commentators that the Renault powered drivers can tell new from old motors which is surprising. Not sure if that holds for the Merc & Ferrari motors?
Ferrari look like they have made some good gains in the last feew races.
I'm not really surprised they can tell the difference. It's only the first season of these engines, so getting the engine life up there is still under development. Plus I wouldn't be surprised if the turbos are wearing out faster than expected due to the ERS system being connected to it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
