As delusional as Maldanado this bloke.
http://www.planetf1.com/driver/18227/9487921/JEV-I-showed-my-potential
Scrappiest of races with penalities, running off the road left right and centre...yet is claiming it as his arrival drive. Where did he qualify again? :) Hack. Off you go to Nissan LMP1 program and leave Romain to fly the F1 flag
obvious troll is obvious
I'm just going to leave this here:
Last 2 races:
Singapore
12 13 Pastor Maldonado Lotus-Renault 60 +66.9 secs 18
13 8 Romain Grosjean Lotus-Renault 60 +68.0 secs 16
Italy
14 13 Pastor Maldonado Lotus-Renault 52 +1 Lap 16
15 99 Adrian Sutil Sauber-Ferrari 52 +1 Lap 14
16 8 Romain Grosjean Lotus-Renault 52 +1 Lap 17
what's that saying? "you're only as good as your last race", or in this case two lol
Edited by hrd-hr30
hmmm,
a "foreign substance" contaminated the electronic circuits in his steering column...
then a later tweet says
the contaminant was a substance used in normal pre-event servicing of the component.
dodgy. If it was a nomal substance used in normal servicing, why would you call it a foreign substance/contaminant? Funny how this normal substance used in normal pre-event servicing only found it's way into the electronics immediately as the cars rolled out for the race, not at the start of the event.
f**k it, i had to listen to years of Webber conspiracy theorists! :P
hmmm,
What substance would you use to "service" a wiring loom that would potentially contaminate the electronics that the loom plugs in to?
Think hair gel is a more believable explanation.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
