Lol at jones yeah, always talking about rosberg being the better driver
He should really stop talking shit, ay
Imagine how big Hamilton's margin to Nico would be by now if it wasn't for the DNFs
^ thats what i was thinking its 2-2 for retirementes isnt it? ah no hamo has had 3
but.... rosberg did manage his 'failing' car at canada as they had the same issue...
Edited by MatthewT85
I thought they were 2-2 for mech failures resulting in race retirement. Homo did have the quali issue with his brakes.
Interestingly both retirments of Homos were when he was trailing Nico and Noco's retirmements were when he was leading. So no matter how you look at its its very close between them with Lewis getting the nod at the moment
Rosberg threw away a race result in Monza and simply was out driven by Lewis in the wet. Even with new tyres was not able to match the pace of Lewis so hats off for a good drive. Interesting to see if Homo can keep the race pace advantage to the end
Vettel insisted he was not leaving because he was being outshone by Ricciardo or because of the rough season he had been having.
“That’s obviously the way people look at it, but that’s not the way I see it,” said Vettel.
“We had a very, very good time and I still hope we have a very good five races this year. I’m not leaving because I don’t like the team, I’m not leaving because I don’t like individuals, or I don’t like the situation.
“I’m not running away from anything. But as I said it felt like the right time, the voice inside me, the hunger to do something new, was bigger, even though it’s not the easiest decision, the easiest consequences to deal with.”
:rolleyes:
Um, you get 25 point for a win. So given he is ten ahead that makes it 35. But then Rosberg would have lost some (7?) so it is 42.
Which just goes to show how much a DNF hurts in the current points system It used to be better when you could drop some rounds off the tally. But it got too confusing for the commentators and everyone else to explain to the great unwashed. So all rounds count and double points for the last round.
Nah they shouldn't. A random dnf shouldn't decide the outcome of the championship. They used to do 9 of 16 then 11 of 16 (from memory and for example) then the lot. Maybe with so many rounds and increased car reliability it isn't so much of an issue but I always thought being able to drop rounds promoted better racing.
Yeah thats a fair argument, that drivers are more willing to go 'all out' if they know they can write the round off if it goes wrong.
But I like having every round count, I think it makes everything a bit fairer, the slightly better drivers should do slightly better if you know what I mean.
Okay- so Hamilton has one extra DNF
Let's assume he'd be at least 17 points ahead if he'd finished first in Melbourne
So we are calling a racing incident a mechanical DNF now? Sorry, Spa doesnt count. Its no different to Germany where Homo crashed into every car on the track during his comeback drive. Only difference this time the team chose to retire the car as he was nowhere. Car didnt break down. And he did the damage to his own car driving like a lunatic back to the pits. Not to say it was right, but in no way should that be counted a mech DNF ... LOL IMHO :)
Yes it should decide the outcome of the championship. That is exactly the point of a championship! It is all about who has performed the best over the course of the championship. It's 100% fair if everyone has to adhere to the rules. That way you will 100% have the person that deserves the championship.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
