Oh Bottas, youuuuu fuucked up; Or was it because you drove so hard in the first two sectors that the rear tyres weren't there at the end?
I wanted so bad for him to upset the Mercedes party. Think if he led from the start he might be able to hold it till the end
  • Like 1
There's another story link at the bottom of that story that just shows how they are playing up Schumacher's improvement. The other story says "he'll soon be able to lead a normal life" despite the fact that he's still unable to move or speak, and his son says in the first story that he's only "waking up" very slowly.
So much for any of the other teams catching them up. They were soooo dominant today. The fact that Rosberg was quicker than Williams, Dan etc on hammered tyres...those things rarely show their true speed.
Seems very ominous for next year too. They only have to tweak this years car to remain dominate whilst RBR, McLaren and Ferrari need to find 1.5-2.0 seconds over Xmas :(
Oh well.
One thing about last nights race was the joke that the FIA call track limits, Vettel in his usual great form driving straight off the track at most corner exits.
Other teams will match the configuration of the Mercs next year. Will hopefully be a fairer race, only time will tell.
Monaco really showed how fast they were as well. Watching the Mercs leave RBR in their dust on the straights. No wonder they are wining everything with the speed those things have.
Oh well.
if they aren't enforcing track limits, it makes sense to exploit it to your advantage.
I think the fact everyone had to conserve fuel helped Rosberg. If others had fuel to burn along with their fresher rubber, it might have been a different story. But yeah, Hamilton just coasting around setting fastest laps was a little bit ridiculous! And Mercedes engines top 5 places.
Unfortunately it seems Rosberg is the one folding under the WDC pressure at critical moments lately. As much as I hate to say it, Hamilton seems to have his number now.
