http://bleacherreport.com/articles/1927268-breaking-down-the-costs-of-racing-in-formula-1-is-spending-out-of-control
Jan 19, 2014
The 2013 Formula One season was filled with reports of teams in financial trouble. It is no secret that many of the smaller teams (and even the race-winning Lotus team) are struggling. At the same time, F1 is bringing in record levels of revenue
...Last October, according to Tom Cary of The Telegraph, CVC, "Formula One’s largest single shareholder, took a $865 million (£538 million) dividend in 2012," and that, "It is believed that CVC, who paid roughly $1 billion (£620 million) for the sport back in 2006, has now gained more than $2 billion (£1.24 billion) from the sport in the last 24 months."
The private firms that own the commercial rights are not interested in what is best for F1, other than if it can make them money. As the numbers demonstrate, they are making quite a lot right now, so, from their perspective, F1 is probably not in need of fixing.
but Bernie says the teams need to share thier bit of revenue out better so he and his mates can continue raking in half billion dollar dividends and mulit billion dollar profits unimpeded!!!
who's the wankers?
Edited by hrd-hr30
Would explain why Button was in such a foul mood during the race and post race. G.O.N.E! Been wishing it for a while but now that it appears a reality I will be a little sorry to see him go. He is a quality fella....even if he can only drive the perfect car he has rather hammered his favoured rookie.
Perhaps Honda would be wise to give Button a year swan song tour and keep the kid in testing-simulator role for another 12 months just to be sure that they have both Button and Alonso pullingmax points every weekend. (something that kid has not been great at doing) For Honda McLaren could be the difference between 3rd or 5th in the WCC next year
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
