  • 4 weeks later...
Started to fill everything up with oils and water to find a fitting at the back of the head to be pushed in from putting the motor in. So last night got the head off in 35minutes new record lol and started stripping everything off so the head can go to the machinist to get some Jun cams supertech double valve springs and new supertech valves :)
  • 4 weeks later...
Still waiting on the head, machinist has been a bit busy ATM should be back next week and then piece it back together. Was trying to sell the roller as I wanna paint the car but no ones interested in paying what I want for it :P
  • 4 weeks later...
Nothing yet. Got the head back on Tuesday but doing some fabrication work atm. Just finished another sump extension and working on a mates 900hp vl doing some custom catch can/header tanks. May get some mates over and get it running on the weekend ;)
Catch can started...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
