Parting out r34 Sedan, most parts available, except front end panels
Rb25det NEO Motor has passed inspection 170psi across the board, race series bearings, has forged pistons, adj. ex cam gear, arp head studs, metal triple layer headgasket, gates racing timing belt, head has port and polish work done. Sold as a long motor with alternator, pwr steer pump and all covers. $4000
RB25 Forward facing plenum with Siemens 630cc injectors, PFI rail and reg with gauge, billet 80mm throttle body with braided fuel lines and speed flow fittings $800
GT3037 4" inlet in very good condition, braided lines and speed flow fittings, stainless steel high mount manifold with adaptor plate for external gate, intake pipe, dump pipe $1600
NEO super spark coil packs $300
Complete manual conversion, r34 turbo box, Exedy cushion button clutch 70%, mount, x member, flywheel, pedals, master slave and lines, tailshaft and shifter, everything you need!! $1600
BC coilovers type BR for r34,front and rear, stiff springs, no leaks $700
Rear adjustable camber arms $80
Front adjustable castor arms $120
Haltech E11v2 with adapted NEO turbo manual loom with boost control solenoid and map sensor, ready for sale $900
R34 sedan rear bar VGC black $100
R34 sedan tail lights in primer $100 pair
Door cards good cond. $25ea
Dash $100
Front and rear seats good cond. $200
Centre console $100
Master cylinder and booster $50
Abs unit $100
Complete good condition boot interior and rubber seal $80
Front brakes pads and rotors vgc pads $200
All door windows, regs, switches and door shells available in black
All interior parts avail
R34 sedan side mirrors vgc In black $80 pair
​msg or PM for pics
Call/msg Johnny 0414696256
Located in runaway bay - Gold Coast
Coilpacks, Haltech, Rear Bar, Tail lights, Door cards, Rear Seats, Centre console, Front brakes pads and rotors, Master cylinder and booster, Abs unit are still available, all else is sold.
Sorry, Drogba brakes are sold also, but check your PM
Also still have the fascia surround for stereo, and couple of interior bits and engine bits still available
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
