skylines australia?
Guest Boxhead
this is typed by me (dave) not boxhead, just too lazy to log out:
i was just thinking about it... and not many qld ppl's cars are going at the moment.
1st you have mine with engine being done now, then you got nismogirl and luke with gearboxes, boxhead with crash damage, nizman with no rego..........and japtaxi is just damn slow :P
so, hopefully by next month the regulars are back on the road and going hard.!!
https://www.sau.com.au/forums/topic/4362-skylines-australia/
Well my skyline was running beautifully, nice and fast, no problems at all! And had been ever since I got that wheel baring replaced 6 months ago! Then I sold the damn thing...
But that's ok cause I got a 200sx with some nice mods as part trade on it...but then I sold that too...
Oh well...That's it for me and performance cars for a while, I have had enough of all of the headaches with insurance and parts and dodgy mechanics etc
Still have my bike though and its more fun anyway :)
https://www.sau.com.au/forums/topic/4362-skylines-australia/#findComment-70308
Guest nismogtsx
Well after saturday nights events my car has spat the
dummy again.... 22psi was not good for most of the car...
The launch got the front wheels in the air slightly...
Now the suspension is creeking....
The boost has half cooked the gearbox...
Clutch packs
The temp has caused the temp sender to die
Which in turn over fueled the car and drowned the O2 sensor.
Mate its time i buy a Excel..... LOL NOT!!!
https://www.sau.com.au/forums/topic/4362-skylines-australia/#findComment-71195
well im back to 3 working cars... hopefully the skyline is back on wednesday.
u shoulda seen them come and pick up the audi today... they had to load it on backwards and on a hill.... the truck *ALMOST* flipped right over... only saved by the fact there was a towball..
very lucky indeed..
https://www.sau.com.au/forums/topic/4362-skylines-australia/#findComment-71274
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
