Hi All,
Listed as below.....low ballers will get no response.
Car is for sale with all my spares bar a spare turbo and the V35 Rays rims. Just needs a new motor!! :P $11K
I wont breakup the items from there lists either:
  • Sway Bars + Front and rear brace - $500
  • BC Coilovers - $750
  • Nismo ECU - $1,250
  • R33 GTR 324mm Brembo callipers and DBA rotors with a near new set of Hawk pads and a half warn set - $650
  • Works Bell Paddle Shifter - $300
  • Complete Black interior - $1000
  • Greddy sonic POD - $150
  • Suction pipe to suit 30/71 BB in standard housings....needs spacer for bush core - $500
  • Mishimoto radiator - $200
  • HDI FMIC including fan - $320
  • Greddy oil cooler + Greddy thermo Sandwich plate + Sensor and output - $450
  • Z33 LSD - $450
  • 3.538 ration front diff(match's Z33 ratio) - $350
  • Greedy informeter - $250
  • Takero's Carbon Fibre rear wing - $400
  • Custom front bar to suit ARX or AXIS....needs repair and spray - $300
  • Nismo exhaust, Decat front pipe, dolphin front pipe - $1,000
  • 610cc injectors, Injector harness and plenum spacer - $500
  • HDI EBC - $100
  • Standard H/F Turbo 30/71 BB core with supporting mods for bolt on(Will need a service) - $700
  • gearbox with Shift kit - $300
More parts to come - I'll take photo's of some of the items. PM me for more detail....don't be offended if I don't respond to low ballers!
All parts are in Sydney......Please note that some of the parts may take some time to get off the car.
cheers
Craig
Any idea what postage would cost to Adelaide for (or if you're even interested in posting them):
Greddy informeter
So much more i'd love to buy.... funds too low though (that black interior would be a huge step up from the horrible tan i have now)
Cheers
Cam
Greddy informeter
Cheers
Cam
I'll post.....it will be under $100 via ego.
  • Sway Bars + Front and rear brace - $500 - SOLD
  • Nismo ECU - $1,250 - SOLD
  • R33 GTR 324mm Brembo callipers and DBA rotors with a near new set of Hawk pads and a half warn set - $650 - SOLD
  • Greddy sonic POD - $150 - SOLD
  • Suction pipe to suit 30/71 BB in standard housings....needs spacer for bush core - $500 - SOLD
  • Mishimoto radiator - $200 - SOLD
  • HDI FMIC including fan - $320 - SOLD
  • Z33 LSD - $450
  • Greedy informeter - $250 - SOLD
  • 610cc injectors, Injector harness and plenum spacer - $500 - SOLD
  • HDI EBC - $100
Update
  • Works Bell Paddle Shifter - $300 - SOLD
  • Complete Black interior - $600
  • Z33 LSD - $450
  • Nismo exhaust, Decat front pipe, dolphin front pipe - $1,000 - SOLD
  • HDI EBC - $100
  • Like 1
I send that kind of stuff Auspost; it will come in under 100cm, and under 20kg.
Estimate will be around $30ish. ;)
Hey Craig,
I dont suppose you've got a harness adapter that is pre-pinned for an E-Manage Ultimate lying around as a result of your R&D efforts do you?
Haha, pre-pinned harness adapter?
They are all hard wired to the oem loom. How many do you think we have tuned so far Dunc? :P
Perhaps you could swap the entire harness, it isn't too hard. Much easier to cut yours up and wire in the universal harness though.
Couldn't remember if there was a 'small' harness between the full loom and ECU - figured it wouldn't hurt to ask :P
I have got a spare engine harness I bought a while back that does have the E-manage cut into it. I paid $100 for it if you want it.
P.S. You will still need to sort the EMU side though.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
