I have a r33 gts-t at the moment and yes i want to make it a rb25de.
I have just found out that i have blown the head gasket, so i was just wondering if anyone would know if i can shave the head and run a thin head gasket to get the comp to at least 10:5:1 at least.
I have a powerfc wired up to my stock 25det loom already so thats why i was just gonna make this motor a DE.
thanks
https://www.sau.com.au/forums/topic/436421-rb25det-to-rb25de/
Prob a lot easier and cheaper to sell the motor as a det and buy a neo n/a motor, I wouldn't bother getting anything machined.
It can be done though, don't see why not, there should be a lot of different thickness head gaskets available for the rb25, just don't go crazy skimming the head, don't want to take to much off.
Its just would be better for me to keeep the det as i have a pfc already wired up to it. so i save money there.
I was just worried about clearences when i shave the head and run a thinner gasket and if it would make an issue?
By the time you're done what you're planning, you could have thrown an N/A NEO6 in there for less. I've seen good RB25DE's go for $500.
Cost vs. time. Remember that machining work and parts will cost you $1k easily. Pretty sure that you'll have to change the pistons to get it to the 10:1 mark.
these threads don't get locked on sight?
TL;DR, engine is incredibly low comp for N/A use, would need to be retuned, still run like shit, and depending on the state, still be illegal. Put N/A motor in or don't drive / sell / use as track car while on P's. Conversion has been done before, with the above mentioned results.
MBS206: you mean upgrade there pal
^^what a load of misinformed dribble, 9.0 to 1 isnt by any means "incredibly low comp" , it will run fine after a retune and it will be okay to run 91 ULP and wont run like shit at all
Been done before, runs like shit.
It's not just comp that's different, but cam profiles etc etc.
^^ yes I already know that it would need a retune (ive also agreed above on that point) 9.0 to 1 is plenty high enough for a na 2.5 litre and most other engines with efficient 4 valve and dohc designs heads. .engines can be de+t and det-t...
Im not arguing that its a waste of money. . . My point is that its achevable /doable
How will different cam profiles make it run like shit?
Cam profiles are designed pending certain applications, youll be completely changing how the exhaust flows and therefrore how the head and cams will breathe.
Kind of like shoving huge overlap cams in a V8 and then bitching the car wont idle like standard...
the engine is designed as one large system, that youre f**king with. It will drive, itll also make way less power than an RB25DE from the factory. There is a reason so many people have complained about driveability after doing this exact conversion...
^^hmm google must have it wrong then because it shows the cam profiles between the r33 rb25det and r33 rb25de are the same - 240 degrees duration and 7.8 mm lift on both inlet and exhaust
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
