Racepace offered us one already done for considerably less than that, id suggest picking up the phone and talking with them......(unsure if it was a one off built one ready to go that they wanted out the door though)
Is that rebuilt with new nearly everything or just the mod done ?
All i remember my son telling me was its was modded and ready to bolt onto a freshly rebuilt dog box we purchased from them when he was there picking it up.
Sort of made me stop for a second and weigh up the work for me to mod it Vs the price it was offered to him for.
Unsure if it was all newly rebuilt and unused, for the price it was offered for i highly doubt it. (it was that cheap)
Since the work I have been driving it for around 700Klms, still on tune in, limiter @ 5000rpm
Had the, clutch, Quaife front diff and the modified transfer case done at the same time.
When I pushed it, it feels balanced and just glides around the sharpest bend. Not sure what is doing what, trannie or Quaife as both were installed at the same time. Already had a Nismo 2-way LSD in the back (No Noise or clunking , ever ?). The new coppermix C Spec clutch is a dream :wub: felt funny as it engages very high compared to the OS Quad I had in it. Being a short arse I can move the seat back a couple of notches and get a better driving position.
I will push it a bit more once the final tune is done and the full power is on the road. I'm sure Paul could test it out and give a better run down on the Pros and Cons of the mix when he has the chance,
Even for a non racer boy, it feels good and you can notice it on a DD.
This is what they did.. Cost $1350,
UPGRADE TRANSFER CASE WITH NEW ADDITIONAL CLUTCH
PACKS .( APPROX 30% MORE CLAMP AREA )
FOUND BROKEN THRUST WASHER, BROKEN NEEDLE BEARING
AND BURNT OUT CLUTCHES AND METAL SANDWICH PLATES
WHEN UNIT WAS STRIPPED DOWN. REPLACE COMPONENTS. INCLUDING SEALS.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
