so e85 will give me power gains which I want, I do a oil change now every 5,000 kms or earlier when it is hot.
I have everything that is needed, I will take it for a tune clean up as running a bit ruff, see power figures and go from there
Cheers for all you input
Anyone wanting to know information about e85 is welcome to PM me, I have been learning it's peculiarities, testing and tuning with it for over 5 years. I am more than capable of dispelling any myths people have been told.
I tried PM'ing you but you can't receive any more messages!! Haha
E85 is rajab (G O D), buy good quality oils royal purple e.t.c or any e85 rated oil and you can be assured of no problems. in winter it is slightly harder to start and if e85 sits for prolonged periods you can have corrosion as it is hygroscopic (all people saying hydroscopic it is not a real word). it is almost detonation proof and returns knock values under 50 at all times. it also gives you almost certain protection against EPA defects for emissions as it is super clean. look to see 300-350 km per tank depending on tune and how you drive.
In summary anyone not running E85 is insane not to mention it is about 40 c cheaper then bp ultimate
Yeh sorry, I get a lot of messages. :P
Have cleaned my inbox now.
don't go crazy big with injectors unless you like idle issues.
I have never seen idle issues with the Xspurts I sell, even the 2000cc injectors idle fine.
As I already mentioned, any SN rated oil will be fine, just change it regularly, and keep the running oil temp over 80 degrees to evaporate any water and ethanol out of it.
E85 is cheaper, but you use 30% more for the same power, don't get too excited because you will end up using twice the fuel you normally would at say a track day or similar. It's worth it though. :)
  • Like 1
Has anyone got an updated list of petrol stations that sell e85 here in adelaide ?
ADELAIDE AIRPORT Sir Richard William Avenue, ADELAIDE AIRPORT SA 5950
MURRAY BRIDGE 155 Adelaide Street, MURRAY BRIDGE SA 5253
POORAKA 876 Main North Road, POORAKA SA 5059
SEATON 169-171 Tapleys Hill Road, SEATON SA 5023
source: http://www.unitedpetroleum.com.au/united/fuel/ethanol-85/e85-store-list
There are currently 9 locations in Adelaide that sell E85, namely:
Caltex
131 O'Connell St, North Adelaide
Corner Panalatinga & Bains Rd, Woodcroft
201 Salisbury Hwy, Salisbury Downs
1916 Main North Rd, Salisbury Park
1129 South Rd, St Marys
443 Main North Rd, Clearview
United
169 Tapleys Hill Rd, Seaton
Sir Richard William Ave, Adelaide Airport
876 Main North Rd, Pooraka
http://www.raa.com.au/motoring-and-road-safety/fuel-information/e85-petrol
  • 4 weeks later...
Just curious, what gains in performance are there from a lightly modified standard turbo car? I have a friend with the following mods who wants e85 but I think the money is better spent elsewhere... Anyway:
Eg rb25 with standard turbo, 12psi, standard motor, pod, fmic, nistune, 3" exh etc?
Making around 190-200rwkw, could he expect the same increases in power as someone with 300rwkw going from 98 to e85?
Edited by s213b
Interesting, I can't think of a reason why any skyline wouldn't be running e85 if it wasnt a daily and had access to a pump.
1. Reduced range
2. Need to map out access to fuel for road trips
Other than that probably not a lot. Awesome power gains and other benefits.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
