Dave, you ripped AU3 !!!
haha thanks to the weather!
Yeh the 17th. But the day before is the Sandown round, so maybe not.
There is another PIARC in sept on the 20somethingth.
Unless dates have changed since I last added them to my calendar
PIARC Sprints @ PI
Sep 27/28
Nov 8/9
Tampered @ Winton
Aug 31
Sep 27/28
Nov 4
Dec 21
WRX had a round listed on Bathurst Sunday but fat f**king chance of going to that one.
PIARC Sprints @ PI
Sep 27/28
Nov 8/9
Tampered @ Winton
Aug 31
Sep 27/28
Nov 4
Dec 21
http://www.piarc.com.au/?page=calendar
PIARC Sprint with Superkart and VicV8s Races.16/08/2014 - 17/08/2014
Collins mentioned making PI an official round since everyone was there but I haven't heard from him about it so haven't bothered to update the spreadsheet.
I think I've only got the R3 update, worth releasing update to spice up Sandown entry or just refresh post?
Nah there wasn't an update as I never got confirmation as it being a round.
That said an update would take 5 mins...
Has anyone got any type of confirmation for the 30th? Have never done a tampered day before but seen nothing by email yet.
LOL Matt. Can you even get to benalla on a tank hehe. Depending on who else comes, we'll see how many jerrys we can borrow and stuff in the boot of the prius.
Oh and Spreadsheet updated post Sandown round 5:
http://www.sauvic.com.au/motorsport/2014_ClubChampionship.xlsx
It might be a stretch - but I reckon I'll make it... :)
RE: bringing stuff in the boot - good stuff. Saves having to make two trips back to town.
Hey Simon - it's not so much a matter of not having jerry cans, more so space to fit them in the car :)
I'm not coming to this Winton, so have 2 x 20L jerry's you can borrow if ya want.
Can't you just turn up at a Tampered day and pay when you get there?
That only works if they have low entry numbers.
Unfortunately there's no way of knowing how many have entered other than calling them, which I just did, but apparently thew lady who organises the Tampered days is away today. Might try again tomorrow.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
