  • Replies 222
^^^ I've got a matched pair of RPM 5 point harnesses for sale. They are just on 2 years old, but are SFI spec so out of date for CAMS use. they don't have the spring clips on the mounting points, but instead have bolt-in plates (ie remove a seat belt bolt, put it through the plate on the end of the harness, bolt it back in). They don't include eye-bolts ('cause they don't need them).They have a "duck-bill" style latch, and the straps are red.
These are the ones:
http://www.revolutionracegear.com.au/index.php?PCID=10413&PSO=245&PSID=9193133&PSV=Primary&CDO=
They were only used three times (actually the passenger side one was only used once). Bought them for a rally-cross event as they were mandatory, then used the drivers one for a track day & a hillclimb. They are as new, except for the date.
Looking for $80 for both, or $50 each.
  • 1 month later...
Hey guys, looking to get my 33 on the road, so I will be needing the following to get it through Regency (I'll probably look for more specifics a little later, more looking to get it driving first.
S2 A/C condenser
S2 intake crossover pipe
S2 dump pipe
S2 front bar - as the wreckers are asking $600 for one, I'll probably just roll with a series one until I can source another, however.
Now as I'm going to have to take it to Regency, I'm chasing stock parts for now. Shoot me a PM on here, thanks.
Edited by Fingerling
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
