Put up a wtb post in drift sales or something lookin for those kind of rims.
If someones dumb enough to go straight in and take rims they'll be dumb enough to offload them to the first person who wants them
  • Like 1
Quite possible they stole them to use on own cars...
Good luck to them, I wouldn't put them on anything of mine. :P
Tyres were cracked and perished, badly enough to wrap them around a tree at a moments notice.
Hopefully they will use them and save you the hassle of finding and taking care of them.
Darwins award should be issued to them once this happens. :)
For those who dont know what the Dawin award is..."The Darwin award is given posthumously to people who have made the supreme sacrifice to keep their genes out of our pool. Style counts"
Edited by GTRPSI
It seems someone has been back, a few M35 Stagea parts have been stolen since. I really hope it isn't someone I know with a Stagea but it's useless to anyone else... Try and help people and this is what I get. :/
Cameras will be installed today fagt, come back and I will be ready for you.
Isn't your workshop all locked n stuff?
So they broke in again?
Or were the parts lying around?
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
