Hey guys got a problem my car didn't make the power I think it should have made.
Rb25det s1
Gt3076r .63 rear
High mount manifold
50mm wast gate with 14psi spring
800cc injectors
Bosh 044 fuel pump
Turbo smart fpr
Upgraded coil packs
Greddy copy intake.
3inch straight exhaust
Blitz dual solenoid boost controller
Microtech Lt12
I only made 296rwhp was the best run of the day at 18 psi
Seems low compared to others iv seen on this site?
Also I did notice that boost drops off from 18 nearly back to 14 at the top. Fuel and air sitting on about 11.6 . Any thoughts?
Edited by DriftSquad
You will need a stiffer spring in the gate imo, and the .63 rear won't be helping things.
Can you get us some pics of your setup? Was the exhaust dropped on the dyno?
I didn't get the chart as I was not happy with the tune. Tuning was done at Godzilla motor sport. On his dynonamics awd dyno
and tell them to send you the tune file
I have a feeling the tune was shit house, also because it's a microtech lt12.. they're so clunky to tune with.. 2x tables to do essentially a single table can do.
I'll ask him to email it to me. Marks pretty good tuner. I mean it is a microguess lt12...
We had to pull some timing cuz she was pinging on boost. He said he thinks the .63 housing is to small
Not sure it's just a stainless manifold with gate mounted to it. The power I Made is not much better then a standard rb with a tune..
If you had bought a decent standalone and left the FFP, stainless manifold, fpr, boost controller etc off the list, you will have had more money to spend on finding the issue on the dyno.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
