Hey people,
I currently have an rb20det with;
-Z32 AFM
-GTR 444cc injectors
-Walbro 250lph pump
-VG30 turbo (rb20 wastegate) running 15psi off a boost t
-Intercooler
-Cat back
-Nistune
Currently running around 190rwkw.
Now I have in my head two paths to go down.
1st, I was thinking leaving the vg30 turbs on there (has nil shaft play and blades look fantastic still) and upgrading to an E85 450lph Walbro pump, larger injectors and getting it tuned on E85. With that in mind what size injectors would I be looking at 750's or 1000cc's. 1000's seem massive to me on an rb20 with small to mild mods?
2nd path I was thinking was to go a hypergear hiflow and retune.
With either option i'm going to upgrade dump pipe and electronic boost controller.
Just after some opinions on which option would be a better bang for my back upgrade for the lack of a better term.
Cheers Steve.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/
Keep the stock manifold.
As the ceramic turbos are untested on E85 I wouldn't risk it. The theory is sound.. It should be cooler, but theres no guarantee the added power won't push the heat back up anyway.
I also agree a highflow to an appropriate size will yield better and more reliable results.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197866
no real point of running e85 unless you want to boost the shit out of it. You won't get as much out of it at 15psi. the VG30 turbo won't hold up to that for long so I'd suggest a HG highflow and a retune on 98 for now, save the injectors for later then switch to e85
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7197935
With respect to whether e85 will make life easier on a ceramic turbo....it might, but I wouldn't count on it. The real killer is not heat, it's shaft speed. The mechanical forces acting on the bond between the ceramic and the shaft and internally in the blades rises at some high power of the rpm. Spin it too fast, and it go poof. Fast is either more air or more boost (just look at a compressor map and see why) and for more power (on e85 even) you need more air. With a fixed restriction downstream (the engine) the only way to get more air is more boost. So you're stuffed anyway.
Decision made above is a good one.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198216
E85 doesnt necessarily mean more boost.
The main benefit is actually the resistance to detonation
I think you should go the e85 path, big pump injectors and tune. Your tuner will be able to add a forkload more timing across the board and make your car drive more fun.
If you go the larger turbo route you'll definately get more lag, less time near boost in a street car and not enjoy it as much.
Or since you didnt mention dump pipe go kando td05 and wind up the boost :-)
My 2c worth
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7198416
Exactly right, you can either add timing, boost or both. I chose boost and it works very well also.
I figured pushing the turbo hard was better than relying on the rods to take extra load, seeing they are stock.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7199989
I thought about it for a bit and came up with if I push the vg on e85 and it lets go I'm up for a turbo anyway.
So I'll get the ss1 in tuned and running and then look at e85 once I'm happy with how the cars going at that point in time.
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7200639
I'd just get bigger injectors / pump and get it all tuned at once with the ss1. The money you'll spend on the re-tune you could have almost done the fuel system.
I just sold brand new unopened id1000's for $500 and bought a walbro 400lph new for $190.
A tune will usually set you back $500-$600
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7201463
For the sake of starting a new thread,
Just sussing out some more options, one of my current injectors is leaking (replaced o-rings and no difference, i assume its cracked maybe?). Im going to upgrade pump and injectors now as well as the SS1.
Basically question is should I just keep the resistor pack and stay with low imp GTR injectors, or revert back to the standard RB20 setup and look for some high imp injectors?
I've noticed there's a sale on RHD at the moment on SARD 800cc's too.
Edit: Also going to pick up a new Walbro pump, if I get the E85 compatible pump will it be safe to use 98 for a while and then when im ready switch to E85 later on? Or is it designed solely for E85?
Edited by Tonks
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208728
Go with deastchwerks, they're bosch ev14s, high impedance and drop in fit for the RB20
http://www.deatschwerks.com/products/fuel-injectors/sport-compact/nissan/skyline/rb20det/1989-94-rb20det
Edited by Missileman
https://www.sau.com.au/forums/topic/439025-rb20-which-path/#findComment-7208776
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
