R32 coupe GTST black
BM50 90
Blue face cluster, 165,000 100
Black electric mirrors 60 ea
Clear indicators, mint condition 170
Jensen 6x9s, with the wood spacers for r32 doors 60 both
Head lights 125 ea mint condition
34 mm water temp adapter 10
Drivers window switch 60
5 bolt shafts 75 pair
Drivers seat with small rip 30
Passenger seat, excellent shape 40
A pillar covers 25
Floor carpet 40
Gab front shocks has springs on them assume lowered 70
Stock rear springs 60
Passenger door glass 20
Drivers door in good shape, with window in black 140
Seat belts, 60 each
Steering wheel centre button, 15
Lower control arms, 60 each, 100 pair
Castor arms 40 each
R33 s1 coupe Black 141,000kms
RB25DET Motor with all accessories, Loom, ECU, turbo (doesn’t look like rb25 std turbo, still Nissan though)
It was running and driving fine but you could hear a slight tapping noise from timing case, assumed idler/ tensioner pulley. Was louder with timing case off. Considering this I have priced it to go!
Also had great oil pressure and spooled up well.
$1200, cheapest complete rb25det you will find.
Complete RB25DET manual conversion.
good condition box, shifted very smooth, no noises
Flywheel, clutch, clutch master, clutch slave, clutch lines, clutch pedal, interior surround (needs boot), shifter, gear knob, tail shaft. The lot.
1450 firm
450 without box
Complete front and rear 5 stud conversion, big 4 pot brakes
Great for S chassis and NA skylines plus others!
Good pads and discs, pulled up really nicely
Hubs, brakes, front uprights, brake lines, brake pads, brake discs, everything you need.
500
Complete rear subframe with all arms only missing hubs/ brakes
with
great upgrade for r32/s13’s and such.
With diff/ shafts 450
without diff/shafts 275
Stock rear springs, great shape, 70
Stock front springs 70
Stock front and rear springs 110
Stock seats
excellent condition
- fronts 40 each
- pair of fronts 60
-full set 100
LSD differential, good condition 175
5 Bolt drive shafts $75
Drivers door, excellent paint
- 80, glass without regulator
-130, glass with regulator
Passenger door,
Complete with glass and reg 130
Door trims
50 ea
Window regs, 70 each
Floor carpet, good condition
40
Seat belts, 60 each
Interior plastics
$10-$30
Dashboard
35, vents at front bit cracked
Steering rack 100
engine cross member 90
Auto Rad, works in manuals too 70
Bare shell, Mint rear quarter panels, not rolled, awesome paint, 150
Front guards
Drivers 80 mint condition
Passenger 40 slight bend at top
Lots more r33 parts as I am stripping the car
Green label Air flow meter 60 bucks
I have about 3 or 4, good upgrade for rb26
Green label afm, not working, has been opened up and glued back closed, 15
6x Series 1 coil packs, perfect working order 80
6x Series 2 coil packs, I have never used them, so unknown 50
Rb25det coil pack loom, works fine, few chipped plugs, 40
ALL LOCATED IN ALTONA, VIC
CAN HELP WITH DELIVERY/ SHIPPING
DELIVERY REQUIRES DEPOSIT
PRICES RELATIVLY FIRM
Although, Discounts if you buy more than one thing.
SMS me for more info and photos
0433200452
I will try check this often but I forget about it
    • Nah that is not actually a lot. Just painting my GTR frontend and the little bits to make sideskirts/nismo flare pieces work correctly/fit on the sedan/mount up correctly came to about $7000. Is it a lot? Sure. None of this is economical. Economy would be shelling the car and buying a 2010 Corolla to commute in. The perspective of all of this is different.
    • I have the re003s’ on my 06 XT Forester Turbo and I highly rate them for street wet and dry
    • I don't see any issues here. I've been saying all along this is a big job, the price reflects that.  When the car comes back perfect I'm sure it will feel like money well spent.
    • Remember, take original quote. Double it. Then add a bit more. It's how any project goes.
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
