Hey guys. My 32 gtr is completely standard besides visual mods, exhaust and gauges swapped for aftermarket ones. My car has felt like it has been performing a bit shitty for a whole now - several months. Just no pull on the top end. I have plans to go for a 300kw build for a while because of this but nevertheless I have still been driving her around taking it easy.
However the other day I was pulling up a hill and she literally wouldn't climb over around 4,000, since then she won't climb over that mark under load but free revving it will hit limiter. I'm thinking turbo issues. I've checked all lines and they are fine. The obvious maf sensors, I've changed the blow off valves to other standard ones I had because they could just be leaking boost. Spark plugs changed and yeah. All lines sussed and nothing.
What do you think?
https://www.sau.com.au/forums/topic/439600-89-32-gtr-not-revving-over-4000/
I believe this is most likely to be a fuel delivery issue.
Filter obstruction
Pump flow
Pump voltage
Pressure regulation
Filter obstruction
Start doing some basic testing by checking for pressure and replacing the fuel filter.
What did you do, swap them with known good ones?
Have you pressure tested the intake?
I cleaned them and then unplugged them individually and revved the motor and she didn't climb over 2500 free revving which is like their fail safe isn't it?
And no I didn't. How would you recommend I do that?
Cheers ;)
Could still be the AFMs. Does it feel like it's surging or does it sort die in the arse when revving (under load)?
Cheers ;)
Don't change it all unnecessarily but definitely start testing things as you go.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
