When talking an engine like yours the term "mob i might try" should never be spoken
Go to someone that knows what he is doing and has a good reputation for this type of work
if I was you I would contact DVSJez and see if he can run it up and tell you what is going wrong
  • Like 1
I have his number and to be honest I am farking sick of this shit.
If they tune rich all the time it will be the same again if I give it back to them
I will call him tomorrow
It is quite possible they haven't set the dead times for the ID1300s correctly
But then there is a heap of things that could not be set exactly correct that need to be which is why you need to take it to someone that knows what they are doing and not just the local mechanic
I do not understand, these blokes have been doing this for a long time and have people out there that swear by there work. You would think this would be easy for them to do right in the first place :/
I will not bore you blokes anymore and thanks for your suggestions :)
  • 3 weeks later...
rockauto is where i got my ls coils
Where do you guys buy your AC Delco D585? Seems like this place has a pretty good deal, http://www.amazon.com/ACDelco-D585-Original-Equipment-Ignition/dp/B000BYD3Y0
http://www.ls2rb.com/buy.html
Goto that link for the supplier who makes them custom coil pack mounting brackets.
Yeah thanks mate
Josh PMed me the link aswell, I'm just making sure i can get everything i need then i will order one or two, so most likely this week
  • Like 1
  • 1 month later...
  • 4 weeks later...
Hi Guys,
Looking at doing this conversion on my SR.. I have found plenty of wiring diagrams so Im pretty sure I can sort it out. BUT if there is a plug and play harness already made by someone I'd be pretty keen to get one.
Also just let me double check, the coils I should be looking to get are D514A? I can get 4 acdelco ones on a bracket etc from ebay for around the $160 mark including plug cables delivered to AUS
As for dwell it seems I should be chasing around the 4ms mark at idle to 3ms top end?
I am running nistune and e85
Edited by RSI497
To summarise the way I understand it;
- D514A are powerful and safe, D585s are powerful (guessing probably more than D514A) but can fire early if you run too much dwell, that is, over 4 ms. Firing early "can lead to major engine damage".
- Genuine coils (AC Delco or Delphi) are more powerful than generics.
I'd guess you'd want maximum dwell at maximum torque, because that's when its going to be hardest to ignite the mixture.
  • Like 1
  • 3 months later...
Has anyone on here swapped to the LS2 coils while using a Power FC?
I'm considering the swap and given the difficulty with changing the Power FC dwell settings, am wondering if the D514A coils will work fine on the stock Power FC dwell settings?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
