Ill talk to him about it but i have not met the guy yet so i dont want to go around there asking the world he was nice enough to offer me to borrow a tool which i found extremely odd as my previous experance with forums and there users there full of douch bags i must say this one seems quiet a bit differant ive had some great responses and helpfull advice.
Cheers :)
superben is right.....
there is no way of testing the coilpacks under "high" boost.
you can swap one and try it, keep going until you find it. but more than likely, a few of them have deteriorated.
can't you test them with an oscilliscope?
I do. But Never used it on coils to inspect if they are faulty. I wouldn't think it would be easy to do. And it wouldn't show up if the coil is arcing out the side through a small crack or something.
Good way of ruining the oscilloscope I would say, unless you can isolate the probe somehow. (I wouldn't be trying it with mine) Still won't show up what's happening under boost without some ingenuity on the dyno.
I don't have RB coils here, but VQ coils don't seem to have any of these issues. ;) (I am running 30-40psi on my original coils) they could possibly work if you removed the ignitor. You would need to make up some new brackets though, and hope the dwell is ok with the stock computer.
the rb coils are awesome, but cos of nissan prices, they are usually the 20 year old originals... slap some new oem in and your laughing.
I was farting around last night with the shitta and discovered more than 1 air leak some of them i created when i decided to go 40psi using Scotts blanking tool as i poped a few hoses of however the factory blow of valve seems to leak at about 4psi so id say the spring is shagged ill make a braket up and try plumb in one i have sitting around its just a black plastic bosch unit cant remember where i got it but it held of on my old E15 to 20psi so should be good ill test again once i fit this or try and source another factory one as i do like a standard looking engine bay.
Cheers again to all of you for your help been very refreshing to get some decent answers with intelect behind them not just replace this that and the other.
Factory bov has a hole in it.that is probably what you heard leaking.
You can plug it up with a grub screw, but it can make the transition onto boost not as nice. Maybe plug it for the test and test drive, then remove once all good.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
