Hey guys, a little dilemma...
R34GTT, Precision 5558 / 0.63 a/r, 40mm gate off housing, plumb-back 3" exhaust system, Power FC, usual support mods, stock coils, stock BOV, 100 cell Lobokka metal high flow cat, 100% street car. 286rwkw at 18-16psi by JEM with old Nistune. Changed to Power FC I picked up cheap to get retune and 'better' ecu / tunability.
Unigroup say there is a restriction in my exhaust system - the cat itself because it wouldn't make any more power going from 20psi to 23psi on 98 fuel. Power actually dropped, made a crappy 270rwkw at 20psi and very retarded timing! Recommended to change cat/ de cat with a stock shell outside etc; Current state is a very safe but very retarded tune (timing) on power FC till I get cat sorted.
Options:
http://justjap.com/index.php/engine/exhaust/catco-3-high-flow-catalytic-converter-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/x-force-3-stainless-high-flow-cat-nissan-type-3.html - highflow cat
http://justjap.com/index.php/engine/exhaust/jjr-stainless-racing-de-cat-pipe-nissan-r34-gt-gt-t-skyline.html - decat pipe / illegal
Please advise what to do, I already have a eGay 100 cell Loboka metal cat fitted (3" entry/exit) and that's a restriction I'm told? What is the most cost-effective way, second hand is ok.
Have read most of the cat threads, too many mixed opinions to decide, my current cat was actually bought based on these forums..
Edited by rondofj
https://www.sau.com.au/forums/topic/440825-restriction-in-the-exhaust/
Most recommended as far as my reading goes is the Venom 100cell metal 5in which I have. But you will definitely get better flow with a decat look alike if you are prepared to take the risk. I am making 314 AWKW with a GT3540 and a three inch exhaust right through. Are you sure your muffler doesn't step down to 2.5in as a lot of big brand Jap ones do? Can you get comparative flow numbers for the Loboka (never heard of it TBH) and the Venom?
Don't know the flow numbers mate, and its got two names Bokka and Loboka if you ebay it..so dodgy as, but surprisingly good build quality and the metal internals have held 2 years of hard driving. Exhaust system is 3" all the way with stock looking oval mid muffler but that is seemingly 3" as well.
Did yavus drop the exhaust on the dyno?
^^ this. How can they say the cat is a restriction without dropping the exhaust in sections?
I ran 310kw with the same cat, I don't think it would be holding you back too much, but who knows...
The difference "could" be down to the different dynos. Does your car feel slower?
Strange because Unigroup seems to have a very good reputation (although anyone can have an off day).
Maybe your second hand PFC is defective?
Did you measure the back pressure? I did a rough measure on mine by making a fitting to go in the O2 sensor hole connected to my boost gauge (not running an O2 sensor).
Lol I dont even know how to measure back pressure, and no, my PFC is sweet, as confirmed by Mark from Unigroup. He said mine was one of not many cars to be very clean with no issues apart from the bloody exhaust. And they're adamant it is the exhaust because it has so many variables and most cars they've tuned which were down on power was found to have a restrictive exhaust, notably the cat etc;
Mine was overheating and just wouldnt make power even with higher boost, power actually dropped, and according to Yavuz thats an exhaust restriction- intercoolers doin a brilliant job, confirmed..
And yes it does feel significantly slower/retarded timing from driving feel. Yavuz confirmed that timing has been retarded a fair bit by Mark.
The cat might also just be failing? Depending on how hot etc, not all CATs last forever.
I mean one brand had a LOT of failures in the latter half of last year, so anything could've happened... But you kinda do need to drop the exhaust to work that out :merli:
Hell it might even be the exhaust itself, all that gets confirmed by taking a couple bolts off - Is it a Jap one?
Ok my exhaust- custom 3' dump from back of turbo to cat, wastegate welded to turbine housing and plumbed back to dump just before cat. 100 cell gay metal cat 3' in/out and 5' body/ bokka brand. 3' pipe from cat to oval mid-muffler. 3' pipe from mid-muffler to X-force 3' straight through
oval muffler.
Gay bokka. lol.
It is a 100 cell cat with a 5 inch body, the metal cats are all much the same construction wise, there is no way it would be a restriction unless the core has shifted, which would be fairly obvious if you dropped two bolts.
I still think it's the cas, but out of interest, do you have a pic of the gate etc?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
