Well that problem was there in the first full tune when I swapped to PowerFC from Nistune, I asked them to fix it this time, it was only a touch-up tune and 'massaging' it in this time after the exhaust fix, nothing major. Its definitely a 3-4sec major power drop with downshifting, sounds tune related aye?
Well it's a result of the ecu doing something dumb, which it determines by how it is tuned. So yes, it is tune related.
I would be cranking some more preload on the actuator. They wouldn't do it while tuning due to the heat around the manifold and turbo scaring them away, but letting it cool on the dyno to try it out would have been cheaper than another tune.
Do you have a boost controller?
If not, what spring do you have in the wastegate?
Only other thing could be the smaller turbine housing (maybe it needs a .8?), but I dont know alot about the precision turbos so I'm not even sure what size the turbo is lol. Anyway if no boost controller then that might improve it, if it alread has a boost controller then it might need some adjusting due to the change in exhaust flow
Boost drop is easily answered. Reduced back pressure in total means less restriction all the way back to the inlet and less boost required for a given amount of flow. Choke off the exhaust again and the back pressure will report back to the intake side at high revs again and Bob's your older male relative....less boost drop off at high flow.
Oh that explains it then..4psi drop is a bit much though.. Yes I have a turbosmart T controller off gate and other end connected to nipple in compressor housing, 18psi spring in wastegate so not lacking in that department. One nipple on the top of the gate is unconnected though?
Cheers-mite be my next mod- will any ebay electronic boost controller like cheap china hdi do or only apexi avcr/ greedy profec spec 2 etc? Hope touch up tune wont be required as its already tuned to 22psi- Im about sick of all this tuning which isnt leading anywhere much.. :(
Yeah better way to do it, holding boost on top and bottom then bleeding the top pressure off. Id say the boost control is the issue with the boost tapering off up top but still doesnt explain the hesitation when downshifting
How's your intake ? 3 inch all the way and free flowing as Tao from hypergear has tested at 250kw there is a difference of 13kw going from 2.5 inch intake to 3inch
Also .63 rear housing may becoming at restriction on a 6cylinder and that power level and boost
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
