obviously something is drawing down on the power. So yeah check all ancillary gear (interior lights etc..) and earthing straps.
I've experienced and heard a lot of people with R32 GTR's who cant leave their GTR sitting for a week or longer period of time. Some of the blame is the car alarm drawing down on the battery.
I did have the several small watch type batterys powering the m80 mongoose alarm drain after several years and had the siren part replaced.
(after ripping out the alarm and smashing it as it makes that orrible dull sound when going flat ....)
Buy a charger and put it on trickle charge whilst not driving it often.
Because if you just disconnect a battery lead terminal and if you have an alarm/imobiliser it will trigger the alarm !
The other thing I have found is that the spark plugs foul easily if it is idled for a while whilst stationary and then turned off, which makes it harder to start next time and drains the battery further while trying to crank over.
I like mine to start every time and on first turn of the key rather than 2-3 cranks. I drive it every other weekend so not often.
So replaced battery, alternator, starter, plugs', ignitor, fuel pump & filter
I understand that the OEM ECU detects the location of all cylinders on cranking. Some of the aftermarket ones look for the position of a particular piston (#1) being TDC so crank a few times on start-up
If your battery is tired this can be an issue.
Edited by Sinista32
Thanks for the feedback,
my money is on the alarm being the culprit ........
Will get it checked out, but in the meantime for <$80 buck I got myself a CTEK MX3.6 to charge the battery and then trickle charge it (my old battery charger was shite anyway......)
Cheers
The Baron
Boot light?
You can put a multimeter in amp mode in series with the battery (keys out of the ignition), then pull fuses to see what causes the drain measured on the multimeter to drop.
I just pull negative off the battery since the GTR is not a daily anymore.
Boot light?
boot light - cunning...... will check and try the multi meter as well
Thanks
just be mindful of which scale you put your meter on. Some cheap meters which dont have fuses are only rated for so much.... or if they are fused, try not to blow them!
I'm having a similar probem, possibly due to the bottom "ring" of the battery terminal has cracked and not making good contact onto the battery post.
Called into my local Nissan dealer to suss out a new setup.
Sit down everyone -
$200
WTF?????
So I'm going to see if I can get someone to weld it shut.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
