Can always use the standard return as a feed and run an extra return line.
044's are rated at 500 working hours on E85.... Or so they say in the box. That's a bloody long time if it's a weekend car.
500hrs!! seriously that is shit....what if its a daily you could potentially be buying pumps every 6 months...no thanks... Even walbros are lasting longer than that...
why do people insist on running and recomending such ancient technology when the market is being updated regularly with newer, better products.......
Depends how you use your car.
Who knows how accurate that is. That might be a "disclaimer" just to cover their asses.
yeah true....doesn't seem to be many people happily running bosch pumps on e85 though...
I'm running 3 044's. 1 in tank and 2 feed. Late last year I had my primary feed pump start to die after 4 years. I noticed as I would start coming on my fuel pressure would drop. Swapped pumps around and problem went away. Maybe the sitting around for 10 months when I popped my engine played a part?
Either way, they're cheap enough.
If this is the case, then logic should be to run the 2 Hicas lines for fuel feed and the old fuel line and return as the return lines for 600Kw with twin Walbos?
Sounds line enough line flow with safety margin?
Just looking in the engine bay with the engine out, those Hicas lines look about the size of the main fuel feed single line but theres 2 of them and ive got a Hicas lock bar in now.
For that kind of power I would look at a Fuelab pump or similar, with variable speed from a PWM ecu output, then run a new -8an teflon line to the aftermarket rail/reg, and use the stock feed for return.
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
