Kindness & Compassion
Remember guys, if you're up to it...
A donation tin for Bowel Cancer Aust will be on deck to receive any $$$ you can spare!
The tin will then be passed to NYTSKY (Dave) a long standing Member of SAU.NSW and his partner Anneke to help with Bowel Cancer Research.
Many Thanks In Advance For Your Grace!
  • Like 2
I can take people in but not back to penrith
Hi Jason,
Thanks for that. Flight# 740iL will contain 5x
Perhaps 1x will enjoy your passenger seat more than the Bimmer's rear jump seat on the way to Riverwood ;)
C U at Kendall St say at 12.35
Hi Jason,
No worries terry see you soon
Thanks to Theo for putting this on and to Terry for organising.
Here are some photos.
14170654423_9e648cd6d6_b.jpgDSC_0003 by Crashdown55, on Flickr
13963921467_ef5dd98f9a_b.jpgDSC_0005 by Crashdown55, on Flickr
14150609085_0b77f4ac64_b.jpgDSC_0006 by Crashdown55, on Flickr
13963918467_21a6b6e614_b.jpgDSC_0008 by Crashdown55, on Flickr
14170648313_28981125c3_b.jpgDSC_0009 by Crashdown55, on Flickr
14150605405_7b9675a102_b.jpgDSC_0010 by Crashdown55, on Flickr
14150603735_865011d845_b.jpgDSC_0012 by Crashdown55, on Flickr
13963954158_ed61df2b8b_b.jpgDSC_0015 by Crashdown55, on Flickr
13963953168_788f08df0b_b.jpgDSC_0016 by Crashdown55, on Flickr
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
