I have a complete TV setup for sale.
Comes with the HiTV Digital tuner, SpecDock(for I phone 5...can convert to Iphone4), English Language conversion, Override switch and all cabling. If you any good at wiring I can explain how to put it in or I can do it at a cost.
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7253021
Issue with tv tuners is if u change regions ypu need to retune. As car is moving (not recommended) signal strength changes and causes screen to freeze or flicker. This is based on my experience. I have recently removed my tuner and gone with a sony double din dvd player ($349).
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7253329
  • 6 months later...
Has anyone actually hooked up a Raspberry Pi and been happy with the results.
Why I ask, is I have a 2005 stagea M35 with factory Nav/TV etc and connected my Raspberry Pi via the aux input at the factory TV tuner box in the rear left quarter.
I have tried two different ways to connect the Raspberry Pi, one via the analogue video output using RCA cable and 3.5 phone jack for sound out connected directly to the aux ( VTR ) input.
This gave me a good sound, but picture quality on the factory screen was fairly poor.
The other method was using HDMI output from the Raspberry Pi then via a HDMI to composite adaptor out to the aux ( VTR ) input again. Results again were much the same, good sound, but picture quality was average.
I'm using XBMC on my Raspberry Pi.
I would like to get this so the picture is of good enough quality that I can easily read the words on the screen without them being a little fussy and very small.
I guessing this may be a case of changing settings in the workings of XBMC maybe, but as of yet I have not managed to be able to change the screen resolution size to see any difference in what I see on the small car screen.
I know if I changed the screen to one that had HDMI input, that I would get a lot better screen picture, but I would think the factory screen would still give reasonable results.
Before anybody suggests taking my car to see who ever, I just wish to point out that I'm in New Zealand.
I'm happy to change any wiring, or direct link something into the factory tv tuner if that is needed.
Any help with this would be much appreciated.
Rotaman
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7413633
Try setting your device to play ntsc format instead of pal that you probably have it set too. Does your screen appear also in black and white. Never had a problem getting a decent picture upto the screen
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7413783
The Raspberry pie outputs in NTSC anyway via the analogue output at around 640p and in HDMI mode it outputs at 1080p then via the HDMI to composite adaptor it is set to NTSC mode on the adaptor. I don't think this is a device problem. I think it is something in the settings of XBMC and I have'nt managed to work out how to change the screen resolution size so that what you see on the screen is large enough and clear enough to see.
Thats why I am looking for someone that has setup a Raspberry pi in their car using XBMC as the media centre.
Unless someone has a better Media Centre they can suggest that will work on Raspberry Pi.
Thanks
Rotaman
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7413873
I don't think you're going to get it much better, unless you change the screen to one which accepts a digital input and/or can display a better resolution.
The small writing on my screen is just legible. Down scaling from HDMI to composite is really not a better idea in terms of quality.
All in all I find the TV more a novelty that comes in handy when waiting for someone or reversing, so I rarely use it.
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7414070
  • 9 months later...
The sound will keep playing when the hand brake is released. It is only video that is cut. Also you will need to do more than earth the handbrake. Unless you plan on driving under 5kmph. There is a speed sensor wire to cut. It is behind the DVD rom.
The best way to remove video block is to get it done programatically.
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7593829
  • 5 months later...
Yeah , not interested in tv, just had trouble with picture on my mini media box.
It was black / white and fuzzy, and I also managed to get it in Chinese so was guessing in the menus.
Set to NTSC and found english, works fine.
Had to make my own lead with Jaycar 4 pin connectors.
Shaved them a bit, glued them together, then had to hack out the socket on the tv tuner a bit too.
Got a good fit in the end.
Soldering was a bit fiddly.
Mounted it up on the rear window shelf so the remote works from the front.
Got 16Gb of music in that thing.
No more cds... :rofl2:
Edited by conan7772
https://www.sau.com.au/forums/topic/441650-tv-upgrade-m35/#findComment-7676435
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
