Nice R32 and a great build what boost are you runing at the moment.
Running 13 psi. It drops back to about 10 at high revs, I guess this cause of the stock turbo, you do notice it a bit and really have to shift earlier to get solid power.
Just a quick update.
The R32 has been packed away in my garage for the next few months as I will be away in Norway with my Fiancee visiting her family.
Oh an I will be going to a little festival known as Gatebil.....
Full writeup coming soon.
  • 1 month later...
Well I am back home now after 2 months of chilling and going broke in Norway so I can continue with the updates.
The day I arrived home I could not believe it but the car started first go!! I had disconnected the battery and luckily it is brand new. I took it for a drive and all seemed to be ok.
The next day however.....
The water line that runs next to the exhaust manifold and around the back of the block had hardened and totally split dumping all the coolant on my garage floor.
Thankfully I had the day off and I got some water hose and fixed it. Was lucky I had the day off cause the next day was another Slidewize Skidpan day up at Gympie.
Car was amazing this day and I put it all down to running the 17" rims and new tyres, It totally changed the car, so much grip and much more controllable at the limit. I never will run worn down tyres for driving events again, they were the reason the car was understeering so much last time.
Not sure if it was going to so many drifting events while in Norway but if feels like I am getting better and can pretty much link all the different tracks they had setup on the day... MAybe time to try it on dry tarmac?
Car is in getting painted right now :)
Following is going down:
OEM rear bumper getting put on with GTR Pods. (Old fibreglass bar was filled with bog and cracks)
Front bar getting resprayed
Roof Spoiler
Took the old bar off and noticed that whoever put that vertex bar on has angle grinded off the rear tow hooks to make it fit... This sucks because I think they are one of the defining looks of the R32, makes it look more race car!!
So I found a wrecked one and cut them off and getting them welded on.
Hopefully get it back this week.
Also chasing GTR front guards and bonnet if anyone knows of some up for sale...
And in super fun happy amazing exciting news......
I ordered this from Japan!
Nismo GT LSD PRO!!
Without a doubt the most expensive thing I have bought yet but from speaking to plenty of guys and considering this car is street driven and I just do wet skid pan days I have been told this is the best upgrade for the money.
I am sure the old one is worn too and lost any of its "limited slip function" 200,000 kms and and more than factory power will probably do that.
So pumped to get it in the car!!
Can anyone recommend a good diff oil to use with it?
  • 5 weeks later...
Sneaky shot of how it is looking now... Could not be happier.
Paint is all done and factory rear bar is on. Also just picked up R32 GTR Bonnet and grill.
Plans this weekend include:
Steering rack bushes
Rear Sway bar and bushes
New Nismo gearknob... (Has an alloy one now and in the Queensland summer it literally scalds your hands when parked outside)
More pictures coming very soon... ;)
Could not help myself, here is a few more.
Will try to get better ones over the weekend.
Decision was made to put on the plates I have owned since I was 23. Actually used to be on my old 180sx back in 2004... funny how fads come and go...
Spent the last weekend under the car replacing the rear swaybar and steering rack bushes.
Rear swaybar is a Whiteline 24mm. Not super hard to put on, hardest thing was removing the old one, there was not room for it to come out because of the exhaust.
No noticeable difference yet, it does feel a little more solid in the rear end but until its driven hard its difficult to tell.
I also adjusted it to the softest setting, so might play around with the 2 settings.
Size comparison between the stock R32 swaybar and Whiteline 24mm.
Upgraded steering rack bushed to Superpro ones.
These where a bitch to fit, actually it was just the drivers side one. There is just no room for it to go in and it can only be mounted one way. I got it in multiple times but it was upside down.
Just used a ton of silicon spray and tied a rope around the steering rack to the strut brace to lift the rack up a bit so I could use 2 hands.
Noticed a big difference with these. Steering is much more direct and responsive. It also feels much more solid.
Old Bushings
Nismo LSD is going in today... little nervous as to how its going to drive. I really want it to retain some streetability.
You can adjust its torque settings so I am going to leave it to Medium and have it set to 1.5 way.
From all the research I have done these are very street friendly and not a whole lot of noise at low speed turns and regular driving but that remains to be seen.
I also went for Fuchs Titan Sintopoid 75W-140 gear oil..
Of all the online research I did this oil was not mentioned once. Everyone seems to say Redline but it was just too expensive and I could not get it in time. The guy at Bursons said this is lightweight and shockproof and the exact same as the Redline stuff. Also said that plenty of race teams are running it now. In fact he only had one bottle left and had to run next door to some Rally workshop to get another for me.
Description online:
Premium gear oil for axle and transfer gearboxes, formulated with fully-synthetic base oils. Offers best cold start behaviour. Suitable for axle and transfer gearboxes with and without limited slip differential. SINTOPOID LS 75W-90 is suitable as trouble shooter for conventional manual transmissions.
Really hope it all works out as I am going to the all Skyline Skidpan day at Gympie this weekend so I am totally out of time if something goes wrong.
Car is looking good man, where abouts did you buy the diff from if you don't mind me asking and how long did it take to arrive?
Bought it from Nengun Online. It was damn expensive... about $1200 plus the customs fees. I was looking forever on Yahoo Japan and locally but none showed up, or if they did they were thrashed.
Of all the guys I have spoken too who drift and race cars they say the best thing you can do is get a proper LSD, and because I wanted to retain drivability and legality I went for this.
Only took about 5 weeks, they told me it was going to be late November but a few days ago I got an email saying it had been shipped from Japan.
Nice thread mate. Looks like a clean car and you are only improving on that :)
I have the Nismo 1.5way and I have to admit it was probably the best mod I did to the car, following by bigger swaybars front and rear.
I also saw you Gatebil thread when you first posted it, super jealous!!! Lol.
Diff is in all but all did not go plan...
So got the diff in yesterday and I admit it "was" awesome. Felt super soild and more aggressive than standard. felt like it tightened everything up in the rear end.
Was a small amount inside wheel spin on tight corners but totally manageable and very easy to live with.
Went to the Skyline Skidpan day in Gympie and it was awesome, very responsive and would kick the rear end out with ease and felt controllable and you did not need to put huge amounts of steering input in to keep it sideways.
And then badness happened...
It felt like it happened instantly but I just got very loud bangs and knock when going around corners. At first I thought it was a cone but nothing was under the car. I got off the track and just did some tight corners and it sounds like the rear wheels are going to fall off, just loud bangs and knocks and very violent.
When driving in a straight line it is fine though, no noises at all. Only around corners.
My mate thinks its the oil, it has broken down and not doing its job. Im unsure...
Anyone have any input on this? I might try to change the oil tomorrow and see if it makes a difference.
Thanks mate!! Yeah already planning Gatebil 2015, I cant wait!! I recommend it to anyone who loves fast cars.
May I ask what oil you are running in your diff? How is yours on the street?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
