Hi guys just a quick what is the most power you can get from a 2.5 neo engine from the skyline 25gt without going turbo or supercharged and what would kind of price Range are you looking at?
Is it possible to get around 300hp ?
If you don't mind spending about 20k on building an engine and then rebuilding it at every oil change then you might get 300hp. But it will drive like crap, use heaps of fuel and be exceptionally unreliable.
  • Like 1
Should just by a magna ey Marc ;)
But yer not a hope of going 300hp (even at the flywheel), would need massive compression, huge cams, itbs.... Although, I shot of giggle gas would liven that boiled egg of an engine up :)
300hp is equal to 220kw, something which not even a stock r34 gt-turbo makes.
Anyways that being said, If you are keen on dishing out 5k+ some guy posted on youtube of his n/a r33. Got 140rwkw out of a N/a, which equates to around 200hp at the wheels.
Initially it was making 92rwkw, so considering its 140kw at the fly from facotry it should be: 140-96= 44kw. 140+44 = 184kw at the fly which is 250hp once modded. So if you spend 5k you can get 250hp, not impossible :P
He lists his mods in the description:
Up until the ferarri 458 came out, the F20C in the Honda s2000 was the most powerful naturally aspirated engine per litre in a car and that made approximately 124hp at the flywheel per litre. 248hp with 2.0L . The F20C is a supremely different engine to the Rb25de. the Rb25de was not made for power, that's what the Rb25det was for.
Is it possible to make 300hp from a smaller capacity N/A engine? Yes. Is it possible to make 300hp from an rb25de? Possibly. Can do you it for less then you'd make 500kw from an rb25det? No.
It's definitely not worth you time or money.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
