Mine are the best. Followed by every other custom fabricator in Australia. Then Tomei, and the very last in the list is the one you will probably buy, the Just Jap dump. :P
No bellmouth is best. Go external gate even better.
If you mean dump and front pipe yes...great cheap mod...if you mean just the dump.pipe itself, its not going to make bugger all difference if you dont change the front pipe as well...so if you are looking at one of those shitty eBay split dumps dont bother...more important is to change your front pipe to a 3inch..or get a bellmouth style dump/front pipe from just jap...but the 3 inch front pipe from dump to cat is most important
yeah I know, it's just I'm having a difficult time believing the OP is still running the stock dump an front pipe. I was under the impression he has already added other mods, when the dump/ exhaust is usually one of the first things that gets changed.
I ran a split dump from Redline:
http://www.redlineperformance.co.nz/products/exhaust/front-dump-pipes/nissan/nissan-skyline-rb20-25det-front-exhaust-pipe/
although people will tell you to buy a bellmouth. Maybe the Just Jap ones are no good but I had no problems with the Redline one.
Now I have a custom set-up from Sinco Customs in Hamilon for my RB30.
I have a 3" exhaust from the turbo dump to a coby 3" resonator then to a 3" RPS straight through muffler. If i go for the turbo dump/frontpipe all in one i'll have to modify my exhaust.
HDI do a nice stainless 3 inch dump to factory 3 bolt flange. Just Jap sold one to a customer of mine a while back, it looked pretty good when I saw it today. The middle two bolts are a pita to get to in-situ of course, I just removed the turbo with the dump pipe attached.
yeah as long as you have 3inch from dump back, thats all you need really...I doubt there is much to be gained from changing it..
A proper split front pipe is fine.
A proper split front pipe is still gay.
FYP.
Understand, the wastegate isn't open a lot of the time, so not only do you have a tiny pipe off the turbine, you are wasting the flow the gate pipe can supply also.
Bellmouth wins with response every time on internal gate turbos, if you must run one. I can't stand most internal gate setups personally.
FYP.
It depends on what type of split. I've seen plenty of shit ones, but also plenty of good ones.
Things could have changed by now, but years ago a split front was the rage and they cost an arm and a leg.
I understand what you're saying about the gate and how it could disrupt and hinder airflow and cause lag. Just like some china turbos were internally gated but had no flap so it opened up before the blade.
Mine isn't laggy, holds boost and is fine 8 years on.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
