more the better,im driving 1.5 hours to represent the mighty 32s,cant have all the club turning up in 33s now.if you want to invite the vr4s go for it,just means more cars to chop,chop,chop,do you see the trend starting,lol
  • Like 1
the evo guys are a good bunch who enjoy theirs cars as much as i enjoy mine,and they drive sensibility on the most part,and dont mind having a chat afterwards.Am looking forward to catching up with you guys,but if you see me coming,just move over,lol.
  • Like 1
As part of the admin team of Qld Evo Owners I would really like to thank SAU for the invites to events like this. We really appreciate it & always have a great time with SAU.
Carl
Who would put you on the Admin team? Lol jokes. Hangover permitting, I may be there.
  • Like 1
Why you gotta be like that? :(
Depends how hard you crash I guess... Colin would probably disagree with you
hopefully no one crashes mate or tears hole in their block - unless it's an LS1
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
