so after i fixed all the boost leaks,i found that the adjustable cam gear bolts came loose. started dialing them back in to spec with test runs that i did 4th gear full boost to where it was and even better so under 3.5k to full boost with more adjustment in them.
while testing i heard a loud backfire and engine stalls, tried to start it after awhile and i only get a loud backfire under cracking.
fuel pump works and plugs just changed now, compression tested and is fine
if valves were gone pretty sure that would have shown up on compression
i'm just curious know what it could be with out taking it apart :P
Edited by Dan_J
https://www.sau.com.au/forums/topic/442359-broke-the-rb20-name-that-failure/
I'm guessing the key in the exhaust cam came off and you put the cas back on in the wrong spot.
Yeah something along those lines is my next bet but seen as the car ran ok until it popped I thought maybe cooler pipe. Sounds like something could have happened to the CAS otherwise but
yea i was thinking it could also be something like that, will give it a once over tomorrow
other wise will swap out the engine when i can be bothered :glare:
Seeing as it was running and then stopped makes me think the exhaust cam pulley may have either jumped a tooth or wasn't done up right and retarded itself.
Would a cooler pipe blown off cause it to backfire on startup? When I blow one off (lol) it will still fire then just die.
Swap out the engine? Because you don't know whats wrong with it?
:S
i work on the principle of expect the worse yet hope for the best and i think i was pushing my luck with air leaks fixed on a responsive untuned motor.... think i'll leave it at that and let trent dail the rest of the adjustment in as shown in the pic attached
Matt wins a prize on this one!
all i have to offer is much cyber #homolove
had a spare so it runs fine now and the beauty of it is these engines are about that price range :P
the reason it broke is because i took off the cam gear cover and did the bolt up as per usual, where as when i dialed in cam gears for the first time i had the cover on making the process back and fourth much longer.
the gear cover has a 4mm spacing to the cas mount doing it up tight with no cover or spacer is its downfall, so i made a spacer out of 3mm flat bar
Edited by Dan_J
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
