I just had an idea, a single valved engine, eg one massive valve on each cylinder, then a second valve or even throttle body in the intake that closes when the exhaust stroke is occuring.
The logistics of this surely would be no more difficult than a typical 2 valve head, it would just require a different valve design for the intake, the increased surface area of the valve would surely be beneficial?
https://www.sau.com.au/forums/topic/442524-single-valve-engine/
Problems I can see so far are the valve would have to operate at double the speed of a normal valve, you would also always get some form of overlap due to the valve cavity where the intake/exhaust meet, though if coupled with direct injection you could remove this.
Edited by Rolls
How are you expecting this to work? have the top of the combustion chamber open to the part of the manifold where the valve is? Because if so you will add all that extra combustion volume - Therefore reduced C:R. Not to mention the issues with heat
If the air is bought in through the side then you lose a bit of volume for the air to be sucked in (proper term is escaping me atm :S)
It's not a good idea, there is a reason they use conventional style valves in engines. Over the years the valve size/location/etc to improve the way the engine performs
I just cant see a way for this to work any better at all
Direct injection 2 stroke as trialed by the Sarich Orbital group. That would only have one set of valves. Supercharged for scavenging purposes. At least that makes it eligible for the Forced Induction section. :action-smiley-069:
All pie in the sky stuff.
One huge negative is that the exhaust valve is hot, the exhaust flow path after the valve is hot. You don't want intake charge flowing over/through hot surfaces.
The overlap problem mentioned above is a real one. There can be no overlap at all when you have to flow exhaust outward, then completely stop that flow before you can start intake flow going the other way. Sure, overlap is only needed because we are restricted by breathing capacity of current designs and this monovalve idea HOPES to provide massive increase to breathing. But I strongly suspect that you will never get enough extra breathing from it to eradicate the need for an overlap period in high speed engines.
if you want to play with engine design and have science help you out along the way...
http://automationgame.com/
highly recommend it. design an engine (inline 4, inline 6, v6, v8, turbos), design the car, choose suspension, wheel options etc. still in beta. plenty of more content to come.
  • Like 1
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
