engine and gearbok.
wheels
hd clutch (have one already but a spare is nice)
gtir brakes
and a few other things....
... spare engine and gearbokchouy, wheels etc to replace the back seat with? you must be able to find another lonely gtr turbo hanging around?
then it really will be just like a mini gtr, except better! siamese 8cyl, 3lt, twin turbo, awd, 4ws mini monster!
...ah I digress
but image the 4wd doughies!
THE TURD LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so a few simple changes, like ditching the hella trendy negative camber, putting 12 year old bridgestone grids and an 8mm spacer, means i have some semblance of grip.
shes going well, apart from us spilling about 60 bucks worth of redline gearbox oil on scotties driveway.
now just waiting on ayayayayaron to source me some sweet tyres.
also scored a rear axle from a super s model, this had rear disc brakes, they dont really do much but the are lighter than the drum rear end. ill clean it up paint it and fit it.
ive order some rotors, and braided brake lines, just need to source some brake pads, but im struggling.
also has n15sss/gtir brakes to replace the 1.6 pulsar brakes i have on now.... shes coming together.
now if someone could find me a sway bar...............
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
