Stock. Has been proven to over 430rwkw by me so far, with a simple external gate off the turbo housing.
More important than the manifold... Which fuel will you be running?
Currently 98 but when I do the manifold and turbo will be united E85. I don't doubt that you can make it work but a standard manifold would not be ideal. Especially for faster spool up and why not. Not to mention how much extra exhaust gas needs to be flowed when running E85
I Probably should have mentioned it's off an Rb25 s2 not a 26. Out of curiosity has your exhaust manifold been ported out?
It's your money, I know of many other parts I would rather spend the $1500 on.
Everything is a restriction to some extent, I just prefer the factory manifold to anything else I have fitted so far, including 6boost.
No, no porting was done, just a 45mm gate off the housing.
What is so hard to believe? The turbo nozzle is 10 times smaller than the runner diameters all added up, how can the manifold be the restriction. The turbo is the obvious restricted part, but hey, go and stick a .63 rear on for 'response'...
I've heard the stock manifold is huge restriction and traps in a lot of heat because it's trapping so much exhaust gas and also because cast iron holds heat well. What do you mean the turbo "nozzle"?
Huge restriction that flows 430+kw?
Anything traps heat when the exhaust gasses are 1000+C. It is the way the materials deal with the heat, and how they allow expansion of the metal without cracking or warping that makes or breaks a setup.
Are we taking RB25 manifolds or RB26 manifolds? Is there a difference in flow? Maybe 26 flows heaps better?
I ran an rb22 with std exhaust mani and HKS2835 with internal gate on 310 rwkw using 20psi on e42.5 for over 2 years full boost 4000rpm - all on track did over 30 events like it fantastic setup
there are other that have done similar or better
so flow myth debunked, ethanol fuel myth debunked
std mani will do it easy all day every day
But its how the gases get from the exhaust valve to the turbine that also plays a big part. In the ays of E85 you tend to be able to mask a lot of things but I can tell you in the days of 98 if you wanted the most out of your RB20 or RB25 then a manifold helped. My 2c is whilst std manifolds make the power, you notic a big improvement in how the car drives and makes its power when driving it on the street or flogging its guts at the track.
My other 2c is if you can get a 6 into 2 into 1 manifold then it will work better again vs the 6boost like 6 into 1 manifolds
This was pretty much my point
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
