Better do some practicing - I have at least painted the car
I have to aswell! hope this time I don't do prac on the wrong track :P
On the topic of painting cars has everybody heard/used the site - http://www.tradingpaints.com/
Allows you to make you own custom paint job and share it with others. Check it out if any of you get the time and post back here with your thoughts. I use it anyways but I think it would be great to have our own paint jobs for the series! :)
This game is frustating me no end
In regards to controlling the cars? How's your fov settings? Have you used a calculator to set the fov? Edited by dontyellpl0x
My FOV settings are... default?
good idea to look at changing your fov if it's still default, I picked up a heap of lap time when I got mine right. Now I actually have my fov 'back' more than it should be for my screen, but everyone has their own sweet spot. But yeah give it try, you'll be surprised :)
Yeah have a play around with it. If you Google iracing fov calculator you could try some of them, or even the in-game calculator. But yeah correct fov changes everything
That seemed to help a bit, set a couple of new personal sector records, can't string together a nice clean lap though.
Then decided to jump in a stock car and try an oval >_<
Nothing better than beating a PB! Done well, really makes the difference doesn't it!
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
