Hi guys, yes I've decided to defect over to the Zed club lol... well not quite... the car I have in mind is a 1988 200ZR... which if you know you're RB's will know is a crossover Zed that came with an RB20DET. Its a Z31. My cuz wants a first car, but dosen't want something expensive, so I'm thinkin of bringing down a car from japan for him. He dsen't like skylines, but he likes the old Zeds. The deal is I use it for a few months while my car's in the shop and then palm it off to him for a couple of hundred less.
Does anyone have any info on this car (other than the usual stats that's available) or know anyone in australia that owns one.
Here's something like what I wanna get though...
Mmm same angine that came in an R31, we'll most probably swap it for a newer Rb20det though
Mmm watanabe's
mmm nice profile too...
https://www.sau.com.au/forums/topic/44364-im-buyin-a-zed-soon/
no i haven't actually... is he on the forum? got pics?
they hardly come up for sale in japan (yahoo auctions or USS auctions) but when they do, they sell pretty cheaply...
Uses NICS type (1st Gen) RB20DET. Not exactly a powerhouse...about 140kW in stock form. Top mount IC suffered similar problems to GTiR...efficiency drops dramatically with increasing temps and increasing boost makes things worse. Best changed for an FMIC (not that easy with the nose shape on these things) or a water/air type.
Note that the sump on these is a different configuration to the R31/R32 spec RB20DET's....sump bowl is at the rear, not the front. May be possible to just swap sump/pick-up but I don't know for sure...
Back in 1988, 140kw is plenty and in an older, lighter chassis it will deliver a decent performance. 160ps (115-120kw) at the time of KPGC10 in 1970s is considered above most competitions already, although it is hard for those figures to impress when presented in the modern world today, as public are 300kw minded these days.
they go for roughly $2100 - $2500 to buy in japan, and then there's the rest of the costs. All up under 8grand to bring into the country. An RB20DET out of an R32 should be about $1k to pick up in oz (I know company that can't get rid of em). I've got the general instructions on how to swap em, including the R32 ECU, so once that's done it should purr along nicely.
Best changed for an FMIC (not that easy with the nose shape on these things) or a water/air type..
I would look at one of FMIC they sell for late model Civics -- they seem to be extremely thin and long, and might just fit behind that front bar.
funky: why not go for something more classic, like a 260 or even a 240? Come to think of it, what do those go for in Jay-phan?
LW.
i have an r32gtst standard i/c including piping if you want a cheap upgrade from the top-mount item...
my bro used to have an R31 (although with the vg30e) and it wass a nice car to drive and nice inside for and older car
the 200zr looks much 'smoother' though
great idea and good luck with the buy!
Waz.
  • 2 months later...
Hay i have one, it is a great car to drive i got it of autostyle in sydney. Dom's orange one is a machiene and just got sold to a guy on the central coast. made 469Kw on low boost without the nos (has only used the nos set up a hand full of times) and thats at the rears. its well cool :). any way i would deffo advise getting one i have no regrets, there comfertable and practicle and great to drive. as well they are an RB20 so plenty of tuning potential. the only problem i have is the suspention, the camber is not adjustable so it is on -3.61 degrees at all times and burns through tires in no time. i am looking into a way of getting this rectified at the moment.
oh, and it's easy enough to fit a fromt mount, i have a R33 V-Spec item in mine and works a treat.
some pics of mine
Then it wasn't trying or it had excessive wheel spin. I was talking to Dom about it and he said that if he tried to use the nos it just wheelspinned on the dyno. I will ask him again but i'm sure i'm right.... i'm always right, ask any one who knows me :D:)
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
