Hey all - I've got the gtr tuned with nistune, however I'm looking at adding another high flow muffler to reduce some noise (and adding a cat converter) would I need to get it retuned? Does nistune retain some ability to alter settings on the go?
might be worth a quick power run to check if the new muffler and cat have caused some restriction and
need some timing taken out of the tune, but if the tune was not on the knife edge it will probably be
ok.
you shouldn't need to change the tune....but if you are a perfectionist you might.... restriction on the exhaust side can increase back pressure and increase cylinder temps,... i wouldn't worry so long as you aren't impeading flow.
depends on how much it impedes the flow...
I tuned my car with a completely f**ked pod filter and then when I put a new one on (same model exactly) we threw it on the dyno just for the hell of it and the afr's were out by 2
I change the muffler constantly on the road, as I use a Varex muffler. Going to a more restrictive muffler shouldn't change the tune that much, but any muffler that flows better will improve the airflow through the engine, possibly making it run leaner which is more of an issue.
If you are running petrol, running a little lean would be bad and possibly cause det. If you are tuned for ethanol, it would likely make bugger all difference.
why would getting better flow out the exhaust cause a lean condition?
yes so if you turn your boost up then sure...but making an exhaust evacuate those burnt hydrocarbons better doesn't change those hydrocarbons....right....so yes it does mean you can add more fuel to your tune and make a bigger bang.
Less exhaust restriction makes it easier to get the exhaust out, making the manifold pressure lower, meaning more boost and better engine flow with no other changes.
If your AFM was out of resolution then it would definitely run lean, as there are no higher cells tuned to add fuel. I would be getting a retune just to make sure. There can be a huge change in engine flow due to simple exhaust changes. Other reasons for running lean could include running out of fuel flow for the extra airflow, even if the tune is compensated.
ok...my brain hurts lol...i don't think i was relating the pressure drop across the cylinder head i was treating it as intake vs exhaust and not really understanding the direct relationship....i understand now thanks :)
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
