Morning skyliners,
After some advice. I have an r32 gtr bought from Vic and looking to engineer it here in nsw.
I was asked to get an emmisions test as it is an r33 rb26.
With the nistune ecu and a 3.5in Zorst it was running 3x over the legal limit for emmisons (stock engine, factory injectors AFM 17psi boost)
I thought replacing the nistune with an r32 gtr stock ecu would run a factory tune. Emmisons was 10x over
Any one got any ideas. I am thinking put the nistune back in and get it dyno tuned back to a stock or more factory tune which will make it closer to the legal limits? Also getting a better cat.
Thanks in advance. I got a quote from a dyno tuner he said 3-4k including exhaust mods. Seems a bit exxy
you could lean on the tune a bit better and take the idle and cruise mixtures closer to 14.7...this will be easier to do with nistune and a good tuner....the stock ecu would do this on closed loop which can make it variable depending on how good your o2 sensors are.
3-4k is way over the top...... where are you located? happy to help. My tuner could re-adjust your cruise and idle mixtures on a road tune for $250.
You will need a factory cat too, I find with Nistune the closed loop is very lazy. I usually disable it completely and run it in open loop..
Easiest way to pass an emissions test, stock cat & E85
Run heat range 5 plugs and mix 5 litres of E85 with 20 litres of 98.
It will pass with flying colours.
DO NOT BOOST IT :)
you have no choice, they control your car you don't control it
I'd agree with above, just get it retuned, dial the boost way back, fix the afrs. But it is a good opportunity to do an e85 conversion.. :)
If your o2 sensors are shot, or the cat is aftermarket, or you have larger injectors, the stock ECU will be absolutely useless. Probably why you had the 10x emissions.
They don't boost it. I used the said method with a friends DE+T and it was said to be better than most econo cars with its result.
You really need a wide band to really know what's happening.
. not sure what functionality the trial version of nistune has.
Edit.
John beat me to it.
Apparently any consult cable should work,but Nistune can't guarantee it will.
Edited by Ben C34
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
