  • Replies 302
well i know it's raining at Oran Park, and it's raining in Winton... we'll see if it's raining between them too!!
HOPE NOT, but it'll still be fun!! :rolleyes:
oh yeah we leave today :)
sorry guys im out for this one :rolleyes: I thought I would have recovered from my illnesss from last week. but still got it and don't think the freezing cold weather down in goulburn will help much :)
hope you guys have fun and get some good footage :(
well! looks like i'm done for!!! gus! you've given me whatever it is you have :D cause now i'm sick as a dog and can't move from bed :O i'll have to pass on wakefield tommorrow!! and spend my day off sick in bed! how rude!!!!
have fun peeps!
Well... I'm out... My car is having a few teething problems, nothing serious, but I'd like them sorted out before I stress the car out...
:P
That's a shame Andrew - I bet you were stinging to take her out.
re teething problems - I guess you have done this enough times to not let it get to you - At first it does, but then you learn to deal with them and it all works out in the end.
The joys of modifying cars :P It never ends...... :)
"let me give ya the hot tip"
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
