I'll take coilpack and bracket posted to perth w.a price?
hold on man...dont have the time nor the inclination right now to strip..looking for a place i can get the car towed straight to and remove some parts. depending on the deal I get I might just give the whole car to one person if they can organise towing to their residence. Also, havnt had a look at the condition of the engine..assuming its okay but want to confirm before I sell to anyone
solution: strip and sell, then buy my 33! everyone wins!
lol...no knowledge or time to strip so prefer to sell the whole car but will see what happens
No good man. Glad ur OK. U have a couple of grand worth of parts with the wreck, strip and sell what u can, scrap the rest and fund a new one.
Thanks man..hope I have that much in there...but probably only if I strip and sell parts individually..
if you need to turn it into money sell it to Fatz to strip
He contacted me , want to ascertain exact condition of the car first... but I may end up doing this to both get the car and memory out of my head and because I donthave the space to store the car nor do I have the knowledge or time to strip the parts and sell it individually.
So far id like to
- pay someone to strip the parts for me...sell shell to wreckers..if they want it and sell parts individually
- sell entire car to someone
but will confirm soon
Thanks for all the support guys...it pains me to even visit the forum and see the word skyline after my ordeal but its something that has to be done...as the holding yard wont be able to hold my car for much longer.
Will update later in the week.
Dude you do not have nothing..you have your life ...live for memories and good times material things mean nothing it can be fixed take every ones advice and swap everything out into another shell it will be a good learning experience and you will gain valuable knowledge about your car chin up dude
well if you get to the end of it all and you're after another 33 and mine's still around, look me up
as nathan said though - cars are replaceable, people aren't.
Thanks guys, its the loss of license that is hitting me as well, otherwise id have another r33 in the garage right now. Public transport is a b*tch.
Engine doesnt seem to have any physical damage
I dont really have the space to store it at my place so if anyone has any suggestions or offers let me know.
I prefer to pay someone to strip the car for me..and i dont want the engine...so maybe we can work something out if someone can organise a place I can tow the car to, get it stripped , they can have the engine + some money my way and Il take the parts I need...failing that , I'll just sell the car as a whole.
Things of value on the car
- splitfires for rb25det s2 - about 10 000km old
- rb25det s2 - 133 000km , no smoke , engine was running perfectly , serviced by Paden at Unique Automotive every 5000km
- straight through 3inch exhaust with gtr front pipe and gtr cat
- hdi boost guage and boost controller
- pedders coilovers - about 7000km old
- jcv splits at the front , pioneer amp, Philips USB headunit
- and ofcourse any other salvageable body parts like rear lights etc
- auto transmission - but these arent worth much
Cheers
Edited by tripsteady
Sure........ But it's better than being in a wheelchair as a quadriplegic!
  • Like 2
I have the time and place to strip it for you if you can pm me what you want to keep I will see if there is any profit in it
Scott
0405428646
PM sent
Point taken
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
