-Genuine Nismo LMGT1 18x10 et20 offset. Nismo 400R sizes
Good Condition, Centres are in excellent condition with Centre caps, Lips could do with a good polish to clean up a few stone chips and scratches around the lips from general wear and tear. Some slight gutter marks as you can see in the pictures.
Bolts and nuts are as new, all original condition. Original stickers in excellent condition.
-Kuhmo ku19 255/40R18 tyres, Roughly 25% tread left.
-Located in Toowoomba 4350 QLD
-Price $2800
-Interstate buyers - Happy to ship at buyers expense, from experience its roughly $150 to freight from Toowoomba to Sydney.
Pictures below-
https://www.sau.com.au/forums/topic/444458-nismo-lmgt1-wheels-forsale-18x10-20/
Thanks for the correction Brett. Appreciated! Yes, negotiating on a BNR32.
I'll take these then lokileah subject to email pics to [email protected] with your full name and address and phone number. That'll be appreciated too!
TERRYY!!! hahah Perfect size for the R32 GTR - im running 17 x 10 +20 now and lots of space left... Just when i saw it - its been taken! haha Nice catch...
Have contemplated keeping them as a collectors wheel, but figure the money could go towards more house renoes at the moment! Such a perfect wheel for 32 gtr, im sure ill regret selling these in the future!
Email sent with requested photos and details to Terry!
  • Like 1
Terry I have the same wheels, great fit :).
You will! I'm taking mine to the afterlife.
  • Like 1
Congrats Terry and seller!
If anyones interested, I will post up my LMGT1 18x10 +20 set tomorrow for sale :)
Wow!
I just looked at my bank account & I can't buy eight!
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
