There are so much better turbos out there then the T67. That thing is OLD SCHOOL tech. 20-30 years old now.
Much better options out there today.
I had one on my evo about 3-4 years ago for about 2 months before I got rid of it for a HTA turbo. Picked up 30kW and about 700rpm in spool. T67 is a dog.
Edited by Tonba
https://www.sau.com.au/forums/topic/444827-greddy-t67-25g/#findComment-7320919
the spagetti Trust manifold was designed with just one wg, however there was a simplified version that utilised 2 wg's..... honestly unless your drag racing, or have a hard on for t67's you might need to look at a different combo.
Cheers
J.
https://www.sau.com.au/forums/topic/444827-greddy-t67-25g/#findComment-7320941
The evo is a small engine to push that much air, but I have seen billet T67's run up to 400kw, certainly not the dog you believe it is, but I agree, there are better options these days if you are willing to spend more cash...
https://www.sau.com.au/forums/topic/444827-greddy-t67-25g/#findComment-7321028
Please, as soon as you go billet, you no-longer have a standard GReddy T67.
I stand by my statement, in that the T67 is a slow spooling nugget. I have tried it with a number of different combos, and it just didn't work (cast Trust manifold, 8cm housing, Trust tubular manifold, 10cm housing). I was better off with a stock frame billet turbo.
I think there are FAR better turbos out there these days. I would take something like a GTX3576, HTA3582R or even a PTE6262 over one anyway of the week.
I don't BELIEVE it is a dog, I know, because I have used the darn thing.
https://www.sau.com.au/forums/topic/444827-greddy-t67-25g/#findComment-7321984
T67 on a 3L 6cyl woulda been fun for sure :)
But a nugget on a 2L 4cyl ;)
Yes, it was a nugget. I can get a HTA3582R or GTX3582R to spool as fast as a T67 on my car... and it makes more power everywhere..
So I don't understand what fuss behind the T67? The compressor is cast (ie heavy), with aero designed 30 years ago and is only 60mm in / 78mm ex. That's a similar size to the GTX 76mm wheel which is a lot more efficient.
The T67-25G might have been respectable 5-10 years ago, but it is simply old technology these days...
https://www.sau.com.au/forums/topic/444827-greddy-t67-25g/#findComment-7322636
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
