75coupe Posted July 3, 2014 Author Share Posted July 3, 2014 Its running a pfc, and while it was tuned atleast three years back, it hasnt had any probs. Im thinking ill have a play with some wiring and see if it changes idle at all... Just wish i had more time to play cars... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7329335 Share on other sites More sharing options...
portaz Posted July 3, 2014 Share Posted July 3, 2014 Rb's are very sensitive to grounding issues as I said unfortunately however hard to hear more than likely it's something you un knowingly did just re trace your steps it could be the silliest thing Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7329354 Share on other sites More sharing options...
Ben C34 Posted July 3, 2014 Share Posted July 3, 2014 The vct plug is pretty much above the top radiator hose pointing towards the engine. Looks similar to an injector plug. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7329397 Share on other sites More sharing options...
75coupe Posted July 3, 2014 Author Share Posted July 3, 2014 Oh ok, thanks for that, im going to search for a wiring issue Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7329437 Share on other sites More sharing options...
89CAL Posted July 3, 2014 Share Posted July 3, 2014 Yep, front of the head, sticks out about 50-70mm and has a red/black plug on it Pull that out and see if it either fixes the problem, or makes the problem constant. If so then not so bad news, might just need a new VCT Solenoid/Switch (this thing your unplugging) or a minor re-tune just to touch up the VCT issue. Perhaps a mix of both Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7329669 Share on other sites More sharing options...
FBRacing Posted July 5, 2014 Share Posted July 5, 2014 Start the car. Take a screw driver and put the metal tip against the injector. Put your ear to the end of the handle. You can hear the injector clicking, it's working. Go thru all 6 and learn what to listen for. This is the first step of diagnosing a bad injector. Step two is ohm resistance. With the motor off, unplug the wire clip to suspected faulty injector. Use a multi-meter to read ohms. You're looking for anything that is not in the 14 ohm area plus or minus 1.5 ohms. You'll use both prongs of the multi-reader and touch each of the injector electrical prongs. Polarity won't matter. This will tell you if the electrical coil is bad inside. Unfortunately they cannot be rebuilt and the whole injector will needed to be replaced. If replacing a single injector, it's wise to remove the rest and having them professionally cleaned and flow matched to the new one. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7330722 Share on other sites More sharing options...
iruvyouskyrine Posted July 5, 2014 Share Posted July 5, 2014 Are 14 ohm considered high or low impedance injectors? Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7330799 Share on other sites More sharing options...
FBRacing Posted July 5, 2014 Share Posted July 5, 2014 If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. These are Nismo 550cc side feed at high impedance. These are aftermarket top feed that can be high or low impedance depending on your personal engine build goals. Easy to spot. The stock side feeds are purple in color if I remember right. Here is a website that can help you more with specs: http://webbersrbguide.com/index.php?option=com_content&view=article&id=64:skline-rb-standard-injectors&catid=45:wiring-electrical-a-ecu&Itemid=23 1 Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7330810 Share on other sites More sharing options...
75coupe Posted July 5, 2014 Author Share Posted July 5, 2014 Yep ive done the screw driver listen and also the swap, injectors are fine it seems so its electrical or vct, ill check it out further and find an answer... Thanks for all your input it is much appreciated, just wish i could dedicate more time to it... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7330943 Share on other sites More sharing options...
iruvyouskyrine Posted July 5, 2014 Share Posted July 5, 2014 If you have side feed injectors (i.e. stock or aftermarket), yes they will be high impedance. If you have top feed injectors, you could be running lows. You can only run lows using an aftermarket computer. Stock ECU only runs high impedance. ImageUploadedBySAU Community1404537253.775014.jpg These are Nismo 550cc side feed at high impedance. ImageUploadedBySAU Community1404537364.267047.jpg These are aftermarket top feed that can be high or low impedance depending on your personal engine build goals. Easy to spot. The stock side feeds are purple in color if I remember right. Here is a website that can help you more with specs: http://webbersrbguide.com/index.php?option=com_content&view=article&id=64:skline-rb-standard-injectors&catid=45:wiring-electrical-a-ecu&Itemid=23 Thanks for the link mate, very helpful Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7330949 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 Ok im still trying to sus this out, ive tried unplugging injectors one at a time and all make a slight difference to how it runs, ive changed spark plugs, removed coil plugs ones at a time each makes a difference to how it runs... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342184 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 Removed cas plug made a small difference but still rough either plug in or not Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342192 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 I havnt had a mechanic do anything on my car other than tune or fab work for years, normally do everything myself, but i may have to bite the bullet cause this has stumped me... Silly cause i feel i caused it. Could an electrical issue cause by moving old heat and weather affected wiring harness... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342203 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 And on a short drive it feels held back and knock was 50, which is completely abnormal... Is it dvsjez time??? 1 Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342211 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 Do you have a fuel pressure gauge on it? Could it just be the filter is blocked? I have seen that cause too many times recently. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342291 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 It could be, but the filter isnt that old, and it was running fine before painting some parts... But now that youve said that perhaps i should change it just to be sure... Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342317 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 No fuel pressure gauge, i do have one for the new fuel setup but its not time yet Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342318 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 It could be, but the filter isnt that old, and it was running fine before painting some parts... But now that youve said that perhaps i should change it just to be sure... Put a mesh 40 micron on there, all the blocked ones I have seen lately have been Ryco style paper ones. Never had an issue with stainless mesh filters. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342492 Share on other sites More sharing options...
75coupe Posted July 17, 2014 Author Share Posted July 17, 2014 Yep was going to use one or two stainless filters for the next fuel setup Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7342528 Share on other sites More sharing options...
Ryno Posted July 19, 2014 Share Posted July 19, 2014 It could be worth checking the contacts on your ECU plug. I had a similar issue with one injector not firing and it turned out to have a bad connection for that injector on the ECU plug. I closed the female connection a little, plugged it back in and the problem hasn't resurfaced. Link to comment https://www.sau.com.au/forums/topic/445103-one-injector-possibly-not-firing/page/2/#findComment-7344493 Share on other sites More sharing options...
