Go into Autobarn and walk towards where they keep the neons and all the other ugly crap you shouldn't ever put on a respectable car.
If your wipers are in bad shape and you want to make them look better, pull them off the car, sand the back a bit with sand paper then hit them with some etch primer, then some satin black, then a matte clearcoat.
https://www.sau.com.au/forums/topic/445287-wiper-blades/#findComment-7331292
The best "look" is no wiper arms/blades (although not legal nor sensible in a heavy rain).
They're not for everyone and most make your car look tacky and cheap.
They are for kids - like coloured wheel nuts, coloured valve caps, big chrommies, mini boxing gloves, dumped on arse. The Queen street spec.
Having said that I do run a set on my 32GTR, same colour as the body, and personally they suit.
Edited by Sinista32
  • Like 1
https://www.sau.com.au/forums/topic/445287-wiper-blades/#findComment-7331326
Coloured parts are only really necesaary when goimg for big hp running -10 sec down the 1/4 kind of thing, unless you have big $$$ and a good set up its really not.worth it, you can however keep the standard look and bring things back to the origional colour with new paints and things alike, much more fun and.looks better
https://www.sau.com.au/forums/topic/445287-wiper-blades/#findComment-7335876
ïðîãðåññèâíûì, áëàãîäàðÿ âåðõíåìó íàõîæäåíèþ ðàñïðåäåëèòåëüíîãî âàëà â ãîëîâêå
Yeah, I bet you would like some coloured wiper blades, you kinky thang you... Please stop, you're getting me all excited.
https://www.sau.com.au/forums/topic/445287-wiper-blades/#findComment-7347108
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
