I have a Greddy/Grex thermostatic oil block adapter hooked up to a Mishimoto 19 row oil cooler in my R33 GTS-T.
The oil cooler is located in the drivers wheel well with ventilation cut into the splash guard to pull air through it.
The issue I'm finding is that my oil temps are very low. On track they sit at 85-90C (previously 120-130C), and on the road in winter they are sitting anywhere between 20-40C (previously 80-90C) with ambient air temps of 8-10C.
I paid extra for a thermostatic adapter so I wouldn't have these issues, but have a feeling it could be stuck open.
Does anyone have any ideas on how I can get my oil temps higher or test the adapter? I don't want to make covers for the cooler as the adapter should be doing this job.
https://www.sau.com.au/forums/topic/445486-engine-oil-too-cold/
You could run 0-30W? It would be at the right viscosity at the track, and wouldn't be too thick at 20C to be a problem but definitely not ideal.
I think you have already tested that the thermostatic valve isn't working, otherwise your oil temperatures should sit at around the opening temperature when idling, just like how a coolant thermostat affects the water temperature.
It may be possible that the lines are not connected properly, ie the cooler is not actually connected to the thermostat ports on the sandwich block?
AFAIK oil pressure the key thing, but yeah 20-40 seems too cold. My HKS kit, which has a thermostat, sits at just above 70 degrees on the stock gauge all the time except at the track. To test coolant thermostats you just put them in a saucepan of tap water on the stove with a thermometer and check the temperature when you see it open. No idea if you could do similar with your oil thermostat, but if its stuck open you should be able to see that when you pull it out.
Agree with double checking the plumbing too.
Are you still running the factory water/oil heat exchanger? If not I suggest you do as it keeps the oil temp in line with the water temp.
This is a very important thing, not only does it pull heat out when hot but it also speeds up getting oil temps higher when cold.
Key point being you want oil and water temps about even.
Im surprised by the amount of people who remove them and just run a external cooler, with or without a thermostate, the factory heat exchanger will help warm up the oil quicker.
One cheap way to know if the thermostate bypass is open is to feel the feed hose to the cooler on a cold day, if its warm and the return pipe is cold, you know its stuck open.
^ yep I cringe when I hear/see people doing it to their built motors!
Then they will say "well just baby it till it gets to the right temp" during that time most of the west and tear is happening but each to their own right?
Oil thermostats are designed to 'Leak' oil to the cooler, they never seal completely so the cooler remains warm, to reduce thermal shock when the thermostat does open.
I would be leaving the water to oil cooler in place as has been mentioned.
Thanks for the feedback so far. Pulled out the thermostat to have a look last night and couldn't find anything wrong. The pin inside isn't stuck (was able to move it with a flat screwdriver).
I was using a 10w-50 oil but have just put Penrite 10w-40 racing in, so hopefully it's a bit thinner at lower operating temps than the 50 weight.
Still using the factory oil/water exchanger as I didn't want to tinker with this and run a pure oil cooler setup. Water temps are around 90C on track but can't remember what they are on street, I think around 80-90C according the the PFC hand controller.
Some pics of the adapter I took yesterday:
What brand is it?
I think mine was closed when i tested it, if slightly cracked open it could be a air bleed function so you dont end up having it open and a buch of air enter your motor when you needed oil. :)
I might get it out tomorrow and take another look, its packed in a box somewhere....
Edited by GTRPSI
RB 20's don't have a heat exchanger like the 26's do. They seem to be going ok for the last 25 years.
Does your oil temp run cool on cold days even through that small gap?
I have a 30 row oil cooler with a 14 inch thermo that switches in automatically at 80c, I also run the stock water to oil cooler.
Most of the time my oil sits around 70 - 80c, even in winter, but I still got the oil up to 140 odd at Sandown on a 30 degree day, after only 3 laps. The water was at 145 though, I probably should have turned the boost down. :P
I am about to install a grex thermostatic oil cooler on my 34gtt,
Where is this stock water-oil heat exchange? Want to be sure I don't remove/alter it
it's where the oil filter sits on.. you'll see water hoses going in/out of it :)
  • Like 1
Interesting, I can't see how your oil can get that cold. My car runs a similar sized cooler in the same location without a thermostat and my oil gets up to around 70 in a few kms and settles at 80 for the rest of the drive / until you give it a sustained bootful. Running the Penrite Racing 10 too.
What sort of gauge are you running and where is the temp sensor located?
It's because you're still running your stock water/oil heat exchanger :)
My oil temp probe is in the sandwich/thermostat plate
If you ever see guys with RB20s with massive oil cooler without thermostats - their oil takes ages to heat up.... (I for one did the same thing on my RB20 back a decade ago, ran an oil cooler without a thermostat - very silly).
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
