Just as the title says, I'm about to do a thermo fan conversion on my R33 as my fan it about to break.
I want to avoid using those adjustable temp switches.
What temperature range should I aim for with the temperature switch?
It's an rb25det running at 12psi.
Also, where would the best place be for the position of the switch?
Cheers.
Thanks guys.
It's there a way to stop the clutch fans from breaking every 6 months or so?
My mate put a new one in his car and it's already got 2 large cracks in it after a little over a month.
Maybe another brand?
I admit that both mine and his cars get thrashed, but that's pretty much what we own them for...
I would say possibly engine mounts crapped causing the engine to move and the fan is hitting.
That or its getting to hot.
If you buy a geniune one it will last another 15 years or so.
Second hand....thats a gamble really.
Dont by gtech......
I don't think it's hitting, mine has 2 cracks between every blade, I'm just getting in early.
My mates actually flew apart while he was drifting, made a complete mess of everything.
His new one already has 2 large cracks but I don't know if it's genuine or not.
Stay away from gtech, check.
While I agree/understand the advantages and disadvantages of thermo fans a lot of drifters do use them, myself included. I have never seen a stock fan break but I don't like the idea of using a stock one with cracks and continuously revving it over 5000rpm. I know that I could buy another but I just like the advantage of thermo fans, it really comes into it's own when you have a nice setup with twin fans and a cross flow radiator.
With drifting (depending on the track) you can sit in a staging area for maybe 2-3 minutes at a time. After flogging the shit out of your car the twin fans really cool it down well. Not saying a stock fan couldn't but thermo fans DO work. I have only ever seen ONE(!) Drift car with a JZ engine running a stock fan, and I'd say over 50% of RB's run thermo fans as well.
These are just my experiences so take it with a grain of salt, but for people who say they don't work/are crap etc then they are incorrect
Never said they dont work, you need to go high end fans/brand to get the most out of them
Then u need to take in to account the power draw.
And if it actually is going to hinder airflow at higher speeds ( ie bad shroud)
He should be getting a bigger 40+ mm radiator instead if he hasnt already.
I track my car with stock fan and 50mm radiator and idles fine after a good heavy 4-5 laps
Edited by jay-rod
I gave up on the thermo I ran in my GTS4 (admittedly without any shroud). Could not keep the engine cool - the slightest incline (at highway speed) caused the thermo to switch on. After I put the standard fan back on, have had absolutely no problem with temperature control.
Figured the couple of kW I gain running the thermo wasn't worth the cost of an engine rebuild.
Jared, I don't think you understand how a thermo fan is designed to work. You will gain a few kW if you set the thermo up the way it was intended, ie to only be working when the engine temperature gets too high.
Alternator only works harder if the thermo fan is on. The majority of the time the thermo isn't on. Only comes on when the engine temp reaches a pre-set thermostatted temperature. Therefore I gain a couple of kW because the engine doesn't need to drive the clutch style (factory) fan.
Which is exactly how the viscous hub works. It only locks up when the viscous fluid is hot. Once locked and after the airflow across the hub has cooled the fluid, it disengages and freewheels again. The effect of the 'drag' on the motor, when the hub is freewheeling, would be negligible at best
  • Like 1
If your changing to thermo fans to gain horsepower, your a long way from being on the right track
If your stock setup works then leave it alone. If you are doing a thermo fan conversion for a practical reason then go for that. I really don't understand people who go on about the horsepower gains from running thermo fans.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
