Im currently upgrading my 32 GT-ST with a high mount, ffp and the rest, and was intending to install a power fc D-Jetro.. However I've recently found they aren't made for rb20, I'm not a ecu expert at all, but I hear you can use an RB25 or an RB26 pfc with some rewiring however it defeats the purpose of plug and play, map and O2 sensor etc. what is the best way to go about the issue? Are there any other known brands of ecu within a decent price range for the rb20 which will allow map, O2 sensor, and plug and play?
Any help is appreciated, thanks guys.
https://www.sau.com.au/forums/topic/445614-ecu-selection-for-rb20/
I was going to say the same as all the above monkeys. Notwithstanding the requirement to run a MAP sensor.
I would ignore the requirement to run MAP and just go Nistune + big enough AFM.
.....who you calling a monkey?
... all though we do like bannanas! ha ha!!
Keep it simple. Power Fc. Easy to tune by just about any tuner. No messing around with std ECU. 10mins to install and start tuning.
Nistune is a good backup option if you cant find a PowerFc but I would be grabbing one of these http://www.skylinesaustralia.com/forums/topic/444035-for-sale-r32-gts-t-power-fc-ecu/
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
