HT have a few home made splitters in the build section
More info mate who is/what is "HT"???. I need help. 2 Build sections Motorsport and Projects, Overhauls and Build-ups.
Cheers
Neil.
Would it make the car unbalanced at all having a front splitter with a factory rear wing?
Always easier to get rear end aero 'grip' than front aero 'grip'. Wings are easy by comparison to splitters.
Neil
Get under the Radical and take some photos ;)
No need Zeb,,, I can tell you whats going on under the Radical and all other Sports/Prototypes.
The Radical has a flat floor which extends all the way back to the rear of the cabin and then it has a massive diffuser much like a DTM car.
The other type is a tunnel system which is basically a diffuser that starts at around the front axles and goes all the way back to the rear of the car. Not practical for sedans as the tunnels go either side of the driver so it's only good for centre seated sports cars.
I've been looking at making a splitter out of this stuff
http://www.alusign.com.au/
has anybody ever used it?
Cheers
Neil.
Hard tuned
http://hardtuned.net/forums/index.php?showforum=389
But there is a f**kload of pictures/how-to's in google if you type 'home made splitters' some from people who actually race (why i mentioned HT)
You guys would know a lot more than myself. But i always thought splitters would only be good on fast tracks with high speed turns and having a low enough car, so it doesn't lift the front up?
And going on from your post Neil, would a splitter that went back further than the front bumper be better? or I'm guessing it would be a case of trial and error, and what type of bumper and other mods are used?
Edited by Stagea97
I made mine out of marine ply (15mm), like Russ's its flat and goes back to the steering rack.
My understanding (not a professional) is the splitter works best when there is the greatest pressure difference under the car. So you need to block off as much of the front of the car as you can so air doesn't go under the car from through the front bar.
I also added a NACA duct on either side under the splitter for oil and intake cooling.
It will only work if it's solidly mounted to the car, if you can't stand on it (80-100kg) it's not going to me doing much.
What we all really need is a fully covered undercar,,,nice and flat leading into a big rear diffuser. That really can't be done,,,the exhaust being our major stumbling block. I just stuck my head under my GTS-T and the front splitter has to stop just before the dump pipe. You could make cutaways around it but what a pain in the arse that would be. It's also very impractical,,,you would lose all your jacking points and servicing/repairs/cleaning kitty litter out after an off at race meeting would be a bloody pain.
So lets forget about the front for a sec and see what else we can do,,,my thinking is one of our major problems is air getting stuffed around by everything under there and then it comes to a screaming halt at the rear bar. Now maybe we should look at making something that lets the air travel out the back more smoothly,,,yes a diffuser would be great but in the interim just smoothing out the air flow back there might help.
Cheers from the aero genius,,,NOT
Neil.
Neil.
Marine ply + Gate = Fire :woot:
Neil.
Yeah that's why not many people do it. Very fiddly making something so custom and vulnerable. Eliminating as much turbulence as possible is the answer...
as above.
I have used both alupanel and normal ply. the alupanel is about $120-150 a sheet, ply $50 a sheet. Ply takes a lot more abuse where as the alupanel is kind of like a knife if you go off track (which i do a lot :) ) and can dig into the ground and rip off. interestingly thats when i learned how much it was helping, in all but 2 or 3 corners a wakie after it came off my car started understeering a heap more, like a normal 31...
my splitter comes out about 80mm from the bar lip and goes back to the crossmember. it also helped a lot with cooling.
ive learnt alot from the aero section in here > http://www.timeattackforums.com/forums/
you still down the road andrew? your more than welcome to come have a popeep
My undertray also goes past the crossmember, as per James. It was conceived to assist solve cooling issues, and to date seems to have hit the mark.
The front end grip improvement is an added bonus, can only think that a decent splitter takes it up a notch or 3 depending on detail.
Composite board prices seem pretty steep down South, more like $80 in Qld.
Thought I might chime in on the discussion here. I've done a lot of fibreglass and carbon DIY so have some thoughts to add.
On the subject of strength, we need to remember that the down force created by the splitter is spread across the entire exposed area. So to say you need to be able to stand on it is a case of over-engineering. Total down force is spread across area to get Force Per Area e.g. PSI or kg/cm2.
The lip I built for my car is only 3-4 layers of fibreglass and one layer of carbon. This was enough to structurally withstand a traffic cone hit at around 40kph. It only cracked and fractured it a bit. Easily repairable.
So I don't think you need to stand on something to test it. The PSI area of the shoe contact area well exceeds any down force you can get from air movement.
What you do need to consider is your mounting point structural integrity (e.g. material & strength).
Short explanation:
When choosing material choose for lightness and strength. If the material isn't strong enough at a pin-point load, reinforce it with other materials such as washers or metal plates layered into the construction.
Long Explanation/theoretical maths (All approximate guesses, so please don't take the maths and measurements too seriously):
Say you are bolting it to the car across 10 mounting screws. For the sake of ease, let's just assume that load is evenly distributed across those points (it won't be and must be considered). Let's also assume that the 10mm bolts are used so there is no real possibility of fastener failure either.
So say 200 kg of down force is spread across 10 points. Each point taking a 20kg load.
Now, a fastener with a 1 cm washer might have an area of 0.8 square centimeters. But you also have to remove the area of the hole for the screw from the material (m5 hole @ 0.25 sq/cm area). This leaves you with about 0.55 sq/cm of area in the material. So you are expecting the splitter material to withstand 36kg/cm2 without pulling through the material.
If you increase the washer size to 2 cm the area increased 3.14 sq/cm (ala PI*R2). Now the area without the M5 size hole is 2.9 sq/cm and thus load over that area decreases to 6.9 kg/cm2. So doubling the size of the washer, re-distributed the workload area over 5 times in this instance.
Load spread across the entire splitter will be the 200kg over the area of the splitter. If the splitter extends 10cm in front and 1.5m wide then the total surface area is about 1500 sq/cm. So the pressure load per sq/cm would be about 0.13kg/cm2.
  • Like 2
Here is a few pictures of the front bar off the race car. Its not a home made splitter(carbon fibre bar made by a local bloke), but it might help with how to mount the bar and splitter and make it quick release. 4 mounting spigots with some simple latches on the top two to hold it in. The bottom two just slide into the receiver tubes (welded to the bottom of the radius rod mounts) and bottom out.
Hopefully that might help with someone having a go at making/fitting something up.
  • Like 3
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
